Not able to connect to remote sink daemon
I have a RFA application which i want to connect to a remote sink daemon.
I have set the following environment on my application:
setenv DACSMUXNAME "dacs_lib.sink"
setenv DACSMUXPING "true"
Also, i have set the following the dacs envs file:
DACS_SNKD_P2P_USAGE=/export/home/vsharma/Config/RFA/;export DACS_SNKD_P2P_USAGE
DACS_SNKD_P2P_USAGE_SIZE="65534"; export DACS_SNKD_P2P_USAGE_SIZE
Next, i have created the ipcroute file in the directory where my RFA application is running. Please find
below the content of the file:
dacs_lib.sink:10.11.32.11:10.11.32.12
where 10.11.32.11 is the ip of the localhost, and 10.11.32.12 is the ip of the remote host.
Still my RFA application is not able to connect to the remote sink daemon.
Can anybody let me know what i need to fix in order for this to work.
Thanks,
Varun Sharma
DACSopen-dacs
You can use the following method to connect to remote sink daemon.
1. Add the following entry in the services database, /etc/services for UNIX or C:\WINDOWS\system32\drivers\etc\services for Windows
dacs_lib 8211/tcp
2. Set the DACSMUXNAME environment variable to <hostname of dacs_snkd>:dacs_lib, e.g.:
On UNIX (bash): export DACSMUXNAME=10.11.32.12:dacs_lib
On Windows: set DACSMUXNAME=10.11.32.12:dacs_lib
[Assuming that 10.11.32.12 is a host on which DACS sink daemon is running]
You can use telnet connect to verify a connection to remote sink daemon.
telnet 10.11.32.12 8211
