Automatic Decompression in HTTP request for Tick History Time and Sales report
Hi there!
I'm trying to download the Tick History Time and Sales report via R library httr.
Apparently, the GET method decompress it automatcally, what could be a real problem for large reports.
Is there a way to work around this?
I read in this page that if the request doesn't have the "Accept-Encoding" header, the response wouldn't have the "Content-Encoding" header and the client shouldn't decompress it, but that is not true, the "Content-Encoding" is still present.
So I don't know if the problem is with the R or with the API.
tick-history-rest-apirest-apirstreaming-pricescompression
13.7k 26 8 12
@leonardo.martins,
The TRTH servers deliver compressed (or not) data depending on several things, as described under heading "Compression" in this page. For an On Demand Time and Sales extraction I believe it should always deliver compressed data, whatever you set in the GET header.
What does the response header contain ? I would expect it to contain this:
Content-Encoding: gzip Content-Type: text/plain
If that is the case, the content is compressed.
But some HTTP clients automatically decompress data when they receive compressed data (Postman does that) I guess you have run into that as well. You must disable httr’s content decoding, using "config(http_content_decoding=0)" in the GET call.
Here is a code snippet that does it:
TRTHRawExtractionResults <- function(token,jobid,Path,Overwrite = TRUE) {
  url <- paste0("https://hosted.datascopeapi.reuters.com/RestApi/v1/Extractions/RawExtractionResults('",jobid,"')/$value")
  r <- httr::GET(url,add_headers(prefer = "respond-async",Authorization = token),config(http_content_decoding=0),write_disk(Path,Overwrite),progress())
  stop_for_status(r)
  return(r)
This is an extract from this article that describes an example of R code that does a time and sales extraction.
If that does not help, please post your code so we can have a look at it.
Thank you very much! It its working perfectly now.
