On TRTH REST API, Is there a better way to find if there was an error ?
When the RIC is wrong I get a 200 status code and I have inspect/parse the notes trying to understand if there was an error. Is there a better way to find if there was an error ? For example, when the start date is after the end date I get a 4xx http status code. How do I understand that there was an error ?
Extraction Services Version 11.0.36705 (cbb5015f7377), Built May 2 2017 18:05:54
User ID: 9012332
Extraction ID: 2000000000470676
Schedule: 0x05bb4169ad8b3016 (ID = 0x0000000000000000)
Input List (1 items): (ID = 0x05bb4169ad8b3016) Created: 25/05/2017 15:30:11 Last Modified: 25/05/2017 15:30:11
Report Template (24 fields): _OnD_0x05bb4169ad8b3016 (ID = 0x05bb4169bf1b3016) Created: 25/05/2017 15:30:04 Last Modified: 25/05/2017 15:30:04
Schedule dispatched via message queue (0x05bb4169ad8b3016)
Schedule Time: 25/05/2017 15:30:05
Processing started at 25/05/2017 15:30:05
Processing completed successfully at 25/05/2017 15:30:11
Extraction finished at 25/05/2017 14:30:11 UTC, with servers: x04q13
Instrument <RIC,ESM9^9> expanded to 0 RICS.
Report suppressed because there are no instruments
tick-history-rest-apirest-api
I see two parts to the question: 1) How are errors handled? 2) How is “incorrect” data handled?
An error response to a request indicates the entire request failed to execute. This means the input parameters supplied to the API were sufficiently bad that no sense could be made of the request. Some requests allow data to be incorrect in some way, but the incorrect data is not a sufficient reason to fail the whole request.
At the REST level, errors are reported via HTTP status codes. A message is part of the response as well. The client SDK translates the HTTP status codes into exceptions.
See: https://hosted.datascopeapi.reuters.com/RestApi.Help/Home/StatusCodes
Incorrect data such as an unknown RIC supplied as input to an on-demand extraction do not cause the whole extraction to fail. So they are not worthy of a REST API error. However, the incorrect data IS worthy of being noted in the response. The types of output vary by API endpoint used. Generally speaking, this means the API returns data that indicates some sort of warning condition.
9.5k 10 5 7
Hello @Beera.Rajesh
You should use HistoricalSearch function to verify if a RIC is valid.
For example:
Request:
POST https://hosted.datascopeapi.reuters.com/RestApi/v1/Search/HistoricalSearch
Authorization: Token <your_auth_token_goes_here>
Content-Type: application/json
Accept-Charset: UTF-8
Prefer: respond-async
  "Request": {
    "Identifier": "TRI.N",
    "IdentifierType": "Ric",
    "Range": {
      "Start": "2017-01-01T00:00:00.000Z",
      "End": "2017-05-24T00:00:00.000Z"
Response: if the RIC is valid, the field Status in the response is "Valid". The Status field
indicates the the validity of the instrument represented.
HTTP/1.1 200 OK
  "@odata.context": "https://hosted.datascopeapi.reuters.com/RestApi/v1/$metadata#Collection(ThomsonReuters.Dss.Api.Search.HistoricalSearchResult)",
  "value": [
      "Source": "",
      "Key": "VjF8MHgzMDAwMDAwMDAwMDAwMDAwfDB4MzAwMDAwMDAwMDAwMDAwMHx8fHx8fHxUUkkuTnw",
      "Description": "Historical Instrument",
      "InstrumentType": "Unknown",
      "Status": "Valid",
      "DomainCode": "6",
      "FirstDate": "1996-01-02T00:00:00.000Z",
      "LastDate": "2017-05-26T00:00:00.000Z",
      "History": []
For more details of the function, please refer to
HistoricalSearch in REST API Reference Tree
Based on my test, if the RIC is wrong, empty value is returned:
Request:
  "Request": {
    "Identifier": "ESM9^9",
    "Range": {
Response:
HTTP/1.1 200 OK
  "value": []
Thank you for the response, but client is more keen about how to identify the errors not just incase of RIC invalidity but in general if they receive any error after performing an extraction.
I have contacted TRTH specialist, Thomson-DSS_SWAT@thomson.com, who should be able to help you on this.
