Use EikonDesktopDataAPi and AdxRtList on VBA Access running on 64bits
hello
i'm facing problems to use EikonDesKtopDataAPI on VBA Access running on 64 bits.
Indeed, while i use the class successfully to initiate RtList functions in 32 bits, i face problems to turn it into 64 bits. i have a message showing that "
ActiveX component can't create object" for this line
set EikonDDA=New EikonDesktopDataAPI.
any help for this matter will be appretiated.
Regards
eikoneikon-data-apieikon-com-api64-bit
4.6k 26 7 22
@anass.yazane.1 Adfin Real-time, which is the library containing AdxRtList, only supports 32 bit environments.
Hi
tahnak you for your answer.
as i get problem when setting eikonDDA (
set EikonDDA=New EikonDesktopDataAP), i will have the same problem if i want to use analytincs functions (such adxbondmodule which are compliant with 64 bits)
Regards
All Eikon COM APIs including Adfin Real-Time and Adfin Analytics are available only as 32-bit libraries, which cannot be used in 64-bit processes. So yes, you will have the same problem with Adfin Analytics.
