There is status message with "Access Denied: User req to IDN for Exch - EXALL" received when I try to start ric chain traversal of 0#.DJI with electron api.
From EmaTrace_13170613312238.xml :
<!-- End Message (Channel IPC descriptor = 472) --> <!-- Outgoing Message (Channel IPC descriptor = 472) --> <!-- Time: 13:16:26:093 --> <!-- rwfMajorVer="14" rwfMinorVer="0" --> <requestMsg domainType="RSSL_DMT_MARKET_PRICE" streamId="4" containerType="RSSL_DT_NO_DATA" flags="0x44 (RSSL_RQMF_STREAMING|RSSL_RQMF_HAS_QOS)" qosDynamic="0" qosRate="1" qosTimeliness="1" dataSize="0"> <key flags="0x3 (RSSL_MKF_HAS_SERVICE_ID|RSSL_MKF_HAS_NAME)" serviceId="467" name="0#.DJI" /> <dataBody></dataBody> </requestMsg> <!-- End Message (Channel IPC descriptor = 472) -->
<!-- Incoming Message (Channel IPC descriptor = 472) --> <!-- Time: 13:16:26:140 --> <!-- rwfMajorVer="14" rwfMinorVer="0" --> <statusMsg domainType="RSSL_DMT_MARKET_PRICE" streamId="4" containerType="RSSL_DT_NO_DATA" flags="0x28 (RSSL_STMF_HAS_MSG_KEY|RSSL_STMF_HAS_STATE)" dataState="RSSL_DATA_SUSPECT" streamState="RSSL_STREAM_CLOSED" code="RSSL_SC_NOT_ENTITLED" text="Access Denied: User req to IDN for Exch - EXALL" dataSize="0"> <key flags="0x7 (RSSL_MKF_HAS_SERVICE_ID|RSSL_MKF_HAS_NAME|RSSL_MKF_HAS_NAME_TYPE)" serviceId="467" name="0#.DJI" nameType="1" /> <dataBody></dataBody> </statusMsg> <!-- End Message (Channel IPC descriptor = 472) --> <!-- Outgoing Message (Channel IPC descriptor = 472) --> <!-- Time: 13:16:51:490 --> <!-- rwfMajorVer="14" rwfMinorVer="0" --> <closeMsg domainType="RSSL_DMT_LOGIN" streamId="1" containerType="RSSL_DT_NO_DATA" flags="0x0" dataSize="0"> <dataBody></dataBody> </closeMsg>
Here this is complete trace file ematrace-13170613312238.zip
Can you please make it clear is it api misuse or something else is abusing?
