CAn someone please share Chain Resolving API in EMA?
Is there any Thomson Reuters standard Library which comes along with EMA package, that will help in resolving chain. I have found the one below but i am assuming this is just for explanation purpose. Please share if someone has any idea for the same.
https://github.com/TR-API-Samples/Example.EMA.Java.ValueAddObjectsForEMA
elektronrefinitiv-realtimeelektron-sdkchain-ric
9.7k 49 38 60
Hi @gaurav.mahajan,
The Chain articles and accompanying source code was created because there was no code built as part of the EMA offering. The source code is very flexible, yet powerful to handle many different capabilities. In addition has capabilities to optimize processing that I think you will find very beneficial.
9.7k 49 38 60
Hi @gaurav.mahajan,
There is a great article, in 2 parts, discussing chains in detail including full source code in Github: https://developers.refinitiv.com/en/article-catalog/article/simple-chain-objects-ema-part-1.
Thanks @nick.zincone.1! I went through that article and Git Source code. Git Source code seems to be developed on TOP of EMA and extended its capabilities for Chain resolving, I was curious to check if there is anything like that coming as part of EMA Library package which we can down load for Reuters API link. Can you please share if something like that exists?
Thanks @nick.zincone.1 for sharing this valuable inputs!
