Sorry @johan.galliez,
Upon further investigations, I found out the last version that supports Solars Sparc is RFA 7.4 which is not available for download anymore. RFA 7.6.X only supports Solaris x86.
RFA C++ 7.6.2 for Solaris is available in the RFA download site here.
Just scroll down and expand the "RFA C++ - OLDER VERSIONS" tag. The RFA Solaris packages should include both 32 and 64 bits library files.
The download should include Solaris Sparc 64bit libraries for OMM data / RSSL connection.
It does not support legacy SSL/SASS connections / MF data for Solaris Sparc 64bit.
UPDATE: Looks like Sparc libraries will only be in versions released prior to 2013, they were dropped in 2013 and will be End of Life from end of 2018.
I found some Sparc 64bit libs in an older rfa7.2.1.E1 release I had on my HDD and as my colleague just added 7.4 was the last version.
hi,
thank you all for your reply and precious help
Last question : it means that Solaris Spark (10 or 11) are not supported anymore
Hello @johan.galliez
Please be informed that the RFA 7.6.x and RFA 8 support Solaris x86 platform only. The RFA 7.4.x is end of life and no longer supported.
