Permid API vs manual search
Hello, I am trying to retrieve the list of companies that match a specific emtity name (e.g. BNP Paribas Securities (JP)). When I use the permid API, I get 5 matches. However , when I use the manual search, I get 67 matches. Is there a limit set on the API? How can I get the same matches on the API? Here is my code:
for search in searches:
    url = 'https://api.thomsonreuters.com/permid/search?q='
    access_token = 'xxxx'
    headers = {'X-AG-Access-Token' : access_token}
    response = requests.get(url + search, headers=headers)
    if response.status_code == 200:
        json_data = response.json()
    res = json_data['result']['organizations']['entities']
    org = []
    for rs in res:
        org = org + [rs['organizationName']]
    newdf = pd.DataFrame([[search,";".join(org)]], columns = ['seach','organisationName'])
    tabres = tabres.append(newdf, ignore_index=True)
pythonintelligent-tagging-apipermid-apiopen-permid-api
@sigrid.rouam
The default number of results returned for each entity is 5. You can change it to 5, 10, 20, 50, or 100 with num parameter. For example:
https://api.thomsonreuters.com/permid/search?access-token=xxx&q=name%3ABNP%20Paribas%20Securities%20(JP)&num=100
For other options, please refer to this document.
Thank you!
