Is an integrated ontology file available?
For the purpose of my new application, I would like to be able to import a PermID ontology file - in OWL or other format (say, acceptable to Protege), containing the (major) entities - Organization, Person, etc. integrated into one file.
Is this file available?
Regards
Colin Goldberg
pythonintelligent-tagging-apipermid-apiopen-permid-api
The information about the Ontologies used by permid.org are available under the “Ontologies” section of https://permid.org/terms.
If you have any further questions, please let us know.
Thank you for your response. However, I see individual files on this page, but not a single integrated file. Is this available? If not, is any help available about how to combine these files into a single one - eg. using Protege or similar software.
Regards
Colin Goldberg
@c3eaf78c-5e01-410a-93af-ded2de9a315d
No integrated file is available and there are no current plans to implement this.
I have tried with Protege but it doesn't work. Protege seems to have a problem with non-exact cardinality in OQL restrictions. Therefore, you could try to combine all the files into one and remove the import declarations and redundant prefixes.
