When using the Check caseId availabilty function in the WorldCheck One API I'm receiving an 404 status. I've not had any issues with other request since receiving my API Key & Secret. Am I doing something wrong?
when you're using the check caseid availability API you will get-
404 - When the given caseId is not found within the current user’s Client, therefore is available to use it as a caseId on any Case.
200- When the given caseId is in use within the current user’s Client, therefore is not available to use on a different Case.
Hope this answers your query!
Regards,
Mehran Khan
API Technical Consultant
Unusual approach to what I've seen before but yes that answers my query thank you :)
Regards,
Matt.
