Max retries exceeded with url: /RestApi/v1/Authentication/RequestToken
  File "E:\Python\Anaconda2\lib\site-packages\requests\adapters.py", line 502, in send    raise ConnectionError(e, request=request)requests.exceptions.ConnectionError: HTTPSConnectionPool(host='192.165.219.152',
 port=443): Max retries exceeded with url:
/RestApi/v1/Authentication/RequestToken (Caused by
NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection
 object at 0x0000000007DA06A0>: Failed to establish a new connection:
 [Errno 10060] ',))E:\Python\Anaconda2\lib\site-packages\requests\packages\urllib3\connectionpool.py:852:
 InsecureRequestWarning: Unverified HTTPS request is being made. Adding
certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/latest/advanced-usage.html#ssl-warnings  InsecureRequestWarning)
Related to this query.
note: in the 27420 question, the max retries exceeded was introduced after download some intruments successfully. not same to the 27048 question.
Hi, Chirstiaan , Is there any download volume limitation for one DSS account?
@Lingyu.Gong, there are various limits, some are documented here. Other limits (numbers of instruments that can be extracted by request type and month) are related to the account itself, and its commercials. I am not a specialist of those, you'd better discuss this with your DSS account manager.
13.7k 26 8 12
@lei.cheng, are you still running into this issue, or has it been solved ?
From the error message I see you are sending an HTTPS request without certificate verification, which generates a warning. You might want to follow the instructions for InsecureRequestWarning in the URL mentioned in the warning.
This query (valid both for DSS and TRTH customers) might be of interest to you. And note you can download DSS DigiCert root and intermediate certificates here.
