We have multiple elektron services running on a given host (delayed, non-delayed, etc.). How do I specify which service the websocket connection will use?
treprdp-apiwebsocketsrrtoconnectionService
Use the service name as the part of key, when opening the subscription:
    "ID": 2,
    "Domain": "MarketPrice",
    "Key": {
        "Name": "IBM.N",
        "Service": "IDN_SELECTFEED"
    "Streaming": true
It's mildly annoying that the "Service" field isn't there in the sample code, even commented out.
Many thanks - would it be possible to have "Key"=>"Service" and "Key"=>"ServiceId" added to the docs?
@Gurpreet. I notice you also using the "Streaming" field - can that be added also?
These and dozens of other fields are documented in the EWA developer guide available here.
See the description of Request message structure in Table 12.
