Using one consumer-client for two RICs?
We are currently in the test phase of consuming data in the News Text Analytics domain.
And we consume two contents, MRN_STORY and MRN_TRNA.
Currently we have two services receiving each content separately and then joining them afterwards.
1
consumer.registerClient(EmaFactory.createReqMsg().domainType(EmaRdm.MMT_NEWS_TEXT_ANALYTICS).serviceName("ELEKTRON_DD").name("MRN_STORY"), eventHandler);
2
consumer.registerClient(EmaFactory.createReqMsg().domainType(EmaRdm.MMT_NEWS_TEXT_ANALYTICS).serviceName("ELEKTRON_DD").name("MRN_TRNA"), eventHandler);
Is there a possibility to consume both together in one consumer-client, which makes joining easier?
elektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-apimrnconsumer
9.7k 49 38 60
Hi @martin.mitry,
Can you elaborate what "one consumer-client" means? In the above code segment, you are opening 2 items which will both be consumed within the same eventHandler. You are requesting from the same consumer.
Hi Nick,
actually we have two different classes each having one of above clients.
Very strange, that I actually didn't try to register two clients, but it seems from your answer that this is possible. I will just try now :-)
Thx
Martin
Thank You @nick.zincone.1 for pointing out that it is possible that multiple clients can be registered to the same eventHandler can handle multiple clients
OmmConsumerConfig config = EmaFactory.createOmmConsumerConfig();
consumer = EmaFactory.createOmmConsumer(config.host(C_HOST + ":" + C_PORT).username(C_USERNAME));
OmmConsumerClient eventHandler = this;
// register clients
