I put the following text in OpenCalais Demo:
"Operating And Financial Results Summary(please Refer To Advantage's Press Release On February 12, 2018 Which Provides Year-end Reserves And An Operational Update)key 2017 Results Which Contributed To Our Strong Earnings Is Included Below:* Record Annual Production Of 236 Mmcfe/d (39,315 Boe/d) And 3 Year Annual Average Production Growth Per Debt Adjusted Share Of 21%* Industry Leading Low Total Cash Costs Of $0.88/mcfe ($5.28/boe)* Low Cost Reserve Additions With An All-in Proved Plus Probable Finding And Development ("F&d") Cost Of $0.84/mcfe ($5.01/boe) And Proved Developed Producing F&d Cost Of $1.32/mcfe ($7.92/boe)* Realized Hedging Gains Of $28 Million Resulting From Our Proactive Commodity Risk Management And Diversification Initiatives. At December 31, 2017, The Value Of Our Future Unrealized Hedging Gains Was Estimated To Be $51 Million* Strong Cash Flow Of $183 Million With An Operating Netback Margin And Cash Flow Margin Of 76% And 71%, Respectively, And* Preservation Of A Strong Balance Sheet With A Year-end Total Debt To Cash Flow Ratio Of 1.2valhalla, Wembley And Progress Area Updatesas A Result Of Our Liquids Rich Drilling Successes In These Areas, Plans Are Currently Being Reviewed To Evaluate Future Drilling Along With Gathering And Processing System Infrastructure Designs To; I) Ensure Future Delineation/appraisal Drilling Is Conducted In A Manner That Systematically Obtains The Most Knowledge And To Optimize Returns On All Multiple Liquids Rich Montney Layers While Preserving Financial Flexibility; Ii) Evaluate Options To Optimize Future Investment Returns Through Integration Of Our Land Blocks Into Our 100% Owned Low Cost Processing And Gathering Infrastructure; And Iii) Evaluate Innovative Value Chain Concepts Which Could Help Mitigate Commodity Price Volatility While Maintaining Attractive Returns On Investment.we Are Excited About These Initial Results And Observe That Additional Industry Locations Have Recently Been Licensed And More Wells Have Been Drilled Adjacent To Our Lands. Area Producers Are Also Evaluating Additional Montney Layers Which Further Demonstrates The Significant Exposure To The Liquids Rich Development Potential That Could Be Realized On Advantage's Land Blocks.wembley (31 Net Sections)advantage's First Delineation Well Located At 12-25-72-08w6 Was Drilled To A Lateral Length Of 2,254 Meters And Was Fracture Stimulated With 38 Stages. The 12-25 Well Was Production Tested Over A Total Of 17 Days At Restricted Rates Due To Regulatory Flaring Limitations And Was Flowed Up The Production Casing At A Draw Down Of Less Than 20% Of The Reservoir Pressure. At The Conclusion Of Our Production Test Period, Our Well Demonstrated An Average Flow Rate Of 1,312 Boe/d Consisting Of 2.9 Mmcf/d Of Gas And 819 Bbls/d Of Hydrocarbon Liquids. The Wellhead Condensate/oil Rate Was 624 Bbls/d With An Additional 195 Bbls/d Of C3+ Liquids Based On A Shallow Cut Extraction Process. The Condensate/oilIs 84% Of The Total Recoverable Liquids. Consistent With Industry Offset Pipestone/wembley Wells DuringProduction Testing And Permanent Production, The Condensate/oil Yield Continued To Increase As Frac Load Water Was Being Recovered. Only 34% Of The Initial Load Fluid In Our 12-25 Well Has Been Recovered And We Anticipate That Liquid Rates Could Continue To Improve With Longer Production Times And The Installation Of Production Tubing To Optimize Wellbore Flow Dynamics. Options For Tie-in Of The 12-25 Well For Permanent Production, Including Connecting The Well Back To Our Glacier Gas Plant, Are Being Evaluated As Near Term Processing Capacity Is Limited In The Immediate Area.progress (39 Net Sections)our First Delineation Well Located At 13-31-77-09w6 Was Drilled To A Lateral Length Of 2,313 Meters And Was Fracture Stimulated With 44 Stages. The 13-31 Well Was Production Tested Over A 6 Day Period And Was Drawn Down To Less Than 40% Of The Reservoir Pressure While Flowing Up Production Casing. At The Conclusion Of The Test, The 13-31 Well Was Producing At An Average Rate Of 624 Boe/d Consisting Of 2.7 Mmcf/d Of Gas And 172 Bbls/d Of Hydrocarbon Liquids. The Wellhead Condensate Rate Was 75 Bbls/d With An Additional 97 Bbls/d Of C3+ Liquids Based On A Shallow Cut Extraction Process. The Condensate/oil Is 63% Of The Total Recoverable Liquids. Consistent With The Profile Of Producing Industry Offset Wells, The Flow Rate Of Our 13-31 Well Increased Throughout The Flow Period As Frac Load Water Was Being Recovered. Only 13% Of The Initial Load Fluid In Our Well Has Been Recovered And We Anticipate That The Production Rate Could Continue To Improve With Longer Production Times And Installation Of Production Tubing To Optimize Wellbore Flow Dynamics. Options For Tie-in Of The 13-31 Well For Permanent Production, Including Connecting The Well Back To Our Glacier Gas Plant, Is Being Evaluated As Near Term Processing Capacity Is Limited In The Immediate Area.*valhalla (40 Net Sections)at Valhalla, Design And Permitting Is Underway To Construct An Initial Facility Installation Which Includes 40 Mmcf/d Of Compression And Liquids Handling Equipment To Collect And Transport Natural Gas And Liquids For Processing At Our 100% Owned Glacier Gas Plant. This Facility Is Designed To Accommodate Liquids Rich Natural Gas Production From Our Recent Four Well Pad And Is Expandable To Accommodate Additional Growth. The Location Of This Facility Could Also Be Utilized As A Hub Where Future Production From Wembley And Progress Could Be Collected And Transported To Our Glacier Gas Plant Such That Netbacks And Investment Returns May Be Enhanced Due To The Benefits Realized Through Economies Of Scale And Integration With Our Established Industry Leading Low Cost Structure. This Facility Is Scheduled To Be Completed In The Fourth Quarter Of 2018.glacier Gas Plant Expansionthe Expansion Of Our 100% Owned Glacier Gas Plant Is On-track For Anticipated Completion In The Second Quarter Of 2018. Two Incremental Process Equipment Units Were Added As Part Of The Expansion Project To Begin Generating New Revenue And Provide More Flexibility And Efficiency In The Plant's Operation Due To Successful Wells In Our Adjacent Land Blocks. One Of The Process Units Added Was An Electric Power Generator Which Will Provide Surplus Electricity Sales (2.4 Mw) Into The Alberta Grid And The Other Process Unit Is A Heat Exchanger. Upon Completion, The Glacier Gas Plant Will Provide 400 Mmcf/d Of Raw Gas Processing Capability, Including 6,800 Bbls/d Of C3+ Liquids Extraction And Will Provide Additional Capacity To Accommodate Future Growth And Process Production From Our Adjacent Land Blocks.market Diversificationadvantage's Continued Market Diversification Initiatives Are Expected To Result In Revenue Exposure To Aeco Prices Of 4% And 28% For The First Quarter And Calendar Year 2018, Respectively. In Addition To Our Dawn, Ontario Market Exposure, Which Comprises Approximately 20% Of Our Current Production, We Have Recently Added Contracts To Transport Natural Gas To The Chicago/ventura U.s. Mid-west Markets. This Will Start In November 2018 With An Initial Volume Of 20,000 Mmbtu/d And Increases To An Annual Average Volume Of 35,000 Mmbtu/d In 2019 And 62,500 Mmbtu/d In 2020 At A Cost Of Approximately Us $1.15/mmbtu To Us $1.20/mmbtu.complementing Our Physical Market Diversification Efforts Are Other Financial Contracts Whereby We Have Both Fixed The Price On A Portion Of Our Natural Gas Production And Entered Basis Contracts To Diversify Revenue To The Henry Hub Market. For 2018, We Have Fixed The Price On 37% Of Our Estimated Natural Gas Production (91 Mmcf/d) At Cdn $3.21/mcf And 46 Mmcf/d For 2019 At Cdn $2.89/mcf. We Also Have 19 Mmcf/d (Approximately 8% Of 2018 Estimated Production) And 25 Mmcf/d Of Our 2019 Natural Gas Production Exposed To Henry Hub Prices With Basis Differentials Of Us $ 0.95/mmbtu And Us $ 0.90/mmbtu Respectively.looking Forwardour 2018 Production Guidance Includes A Slight Reduction In Production Volumes During The Second Quarter Of 2018 Followed By A Continued Increase Through The Second Half Of 2018 To Achieve Our Production Guidance Of 255 To 265 Mmcfe/d. The First Quarter Is Anticipated To Be 242 To 246 Mmcfe/d And Approximately 3% Lower In The Second Quarter Of 2018 To Accommodate A Short Plant Outage In Order To Complete The Integration Of New Equipment And Commissioning As Part Of The Glacier Gas Plant Expansion. Average Liquids Production For 2018 Is Targeted At 1,900 Bbls/d, Exiting The Year At 2,400 Bbls/d. Advantage's $175 Million Capital Program For 2018 Is Weighted Approximately 60% To The First Half Of The Year, With The Majority Of Spending Occurring During The First Quarter Including Completion Of The Glacier Gas Plant Expansion.advantage's Montney Development At Glacier Has Been Successfully Executed Since 2008 Based On Maintaining An Industry Leading Low Cost Structure, Preserving A Strong Balance Sheet And Preserving Operational And Financial Flexibility. These Factors, In Conjunction With An Increased Focus On Liquids Development In 2018 And Beyond Will Provide Advantage With The Ability To Respond Promptly And Responsibly To Market Conditions. We Wish To Thank All Of Our Shareholders And Our Board Of Directors For Their Ongoing Support And Most Importantly, All Of Our Peoplewe Look Forward To Reporting On Our Progress Through 2018.fourth Quarter And Full-year Operating And Financial Summarydisclaimer: The Table Has Been Omitted (The Document Can Be Viewed At Http://advantageog.mediaroom.com/2018-03-05-advantage-announces-2017-results-and-drilling-successes)production Increased 11% In The Fourth Quarter Of 2017 To A Record 245 Mmcfe/d (40,857 Boe/d) With 2017 Average Production Higher By 16% To 236 Mmcfe/d (39,315 Boe/d), As Compared To The Same Periods In 2016. Natural Gas Liquids Production Has Grown To 1,227 Bbls/d For The Fourth Quarter Of 2017, A 29% Increase From The Same Period In 2016 And Consisting Of Approximately 70% Condensate. Production Met Our Original Guidance Targets Despite Significant Third Party Pipeline Restrictions Which Impacted The Majority Of Western Canadian Producers Through 2017.funds From Operations Were $43.9 Million Or $0.24/share For The Quarter And $183.2 Million Or $0.99/share For The Year. Higher Production, Market Diversification Initiatives, A Proactive Hedging Strategy And Industry-leading Low Corporate Cash Costs Of $0.88/mcfe For The Year Resulted In Strong Funds From Operations.net Income Earned Of $95.0 Million Or $0.51/share For The Year And $21.4 Million Or $0.12/share For The Fourth Quarter Of 2017. Higher Production And Gains On Our Derivative Contracts Resulted In Net Income Throughout 2017. Excluding Unrealized Gains On Derivatives Of $17.2 Million And $73.3 Million In The Three Months And Year Ended December 31, 2017, Advantage Would Have Still Generated Significant Net Income.achieved A 3 Year All-in Capital Efficiency Of $15,333/boe/d. Advantage's 2017 All-in Capital Efficiency Of $17,000/boe/d Includes $80 Million For Our Glacier Gas Plant Expansion And $7 Million For Land Acquisitions, Which Results In A Capital Efficiency Of $11,100/boe/d When These Expenditures Are Excluded.continued Market Diversification Such That Only 28% Of Our Estimated 2018 Revenue Is Exposed To Aeco Prices. This Market Diversification Includes Fixed Price Hedges, Henry Hub And Dawn Market Exposures And Access To The Alliance Pipeline In 2018 Which Will Provide Further Opportunities Into The Mid-west U.s.the Corporation's Audited Consolidated Financial Statements For The Fiscal Year Ended December 31, 2017 Together With The Notes Thereto, And Management's Discussion And Analysis For The Year Ended December 31, 2017 Have Been Filed On Sedar And With The Sec And Are Available On The Corporation's Website At Http://www.advantageog.com/investors/financial-reports/2017-2. The Corporation's Audited Consolidated Financial Statements For The Fiscal Year Ended December 31, 2016 Are Also Available On The Corporation's Website Via The Same Webpage. Upon Request, Advantage Will Provide A Hard Copy Of Any Financial Reports Free Of Charge.this Document Has Footnotes And They May Be Found At: (Http://advantageog.mediaroom.com/2018-03-05-advantage-announces-2017-results-and-drilling-successes)source: Advantage Oil & Gascopyright 2017 Contify.com"
I specifically wanted organization PermIDs and the demo returned the ones I wanted: for example: 4295860402 (Advantage), 5035166520 (Valhalla).
But when I did Calais Tagging using SwaggerUI I get this result:
{ "doc": { "info": { "calaisRequestID": "88efb6c8-e32b-97b6-1629-1149a9924e42", "id": "http://id.opencalais.com/YtHc7F5yIrMTsJW-zmlr5A", "ontology": "http://mdaas-virtual-onecalais.int.thomsonreuters.com/owlschema/11.5/onecalais.owl.allmetadata.xml", "docId": "http://d.opencalais.com/dochash-1/5f0a3b27-40f9-38fb-b356-c200a8f6d087", "document": "Operating And Financial Results Summary(please Refer To Advantage's Press Release On February 12, 2018 Which Provides Year-end Reserves And An Operational Update)key 2017 Results Which Contributed To Our Strong Earnings Is Included Below:* Record Annual Production Of 236 Mmcfe/d (39,315 Boe/d) And 3 Year Annual Average Production Growth Per Debt Adjusted Share Of 21%* Industry Leading Low Total Cash Costs Of $0.88/mcfe ($5.28/boe)* Low Cost Reserve Additions With An All-in Proved Plus Probable Finding And Development (\"F&d\") Cost Of $0.84/mcfe ($5.01/boe) And Proved Developed Producing F&d Cost Of $1.32/mcfe ($7.92/boe)* Realized Hedging Gains Of $28 Million Resulting From Our Proactive Commodity Risk Management And Diversification Initiatives. At December 31, 2017, The Value Of Our Future Unrealized Hedging Gains Was Estimated To Be $51 Million* Strong Cash Flow Of $183 Million With An Operating Netback Margin And Cash Flow Margin Of 76% And 71%, Respectively, And* Preservation Of A Strong Balance Sheet With A Year-end Total Debt To Cash Flow Ratio Of 1.2valhalla, Wembley And Progress Area Updatesas A Result Of Our Liquids Rich Drilling Successes In These Areas, Plans Are Currently Being Reviewed To Evaluate Future Drilling Along With Gathering And Processing System Infrastructure Designs To; I) Ensure Future Delineation/appraisal Drilling Is Conducted In A Manner That Systematically Obtains The Most Knowledge And To Optimize Returns On All Multiple Liquids Rich Montney Layers While Preserving Financial Flexibility; Ii) Evaluate Options To Optimize Future Investment Returns Through Integration Of Our Land Blocks Into Our 100% Owned Low Cost Processing And Gathering Infrastructure; And Iii) Evaluate Innovative Value Chain Concepts Which Could Help Mitigate Commodity Price Volatility While Maintaining Attractive Returns On Investment.we Are Excited About These Initial Results And Observe That Additional Industry Locations Have Recently Been Licensed And More Wells Have Been Drilled Adjacent To Our Lands. Area Producers Are Also Evaluating Additional Montney Layers Which Further Demonstrates The Significant Exposure To The Liquids Rich Development Potential That Could Be Realized On Advantage's Land Blocks.wembley (31 Net Sections)advantage's First Delineation Well Located At 12-25-72-08w6 Was Drilled To A Lateral Length Of 2,254 Meters And Was Fracture Stimulated With 38 Stages. The 12-25 Well Was Production Tested Over A Total Of 17 Days At Restricted Rates Due To Regulatory Flaring Limitations And Was Flowed Up The Production Casing At A Draw Down Of Less Than 20% Of The Reservoir Pressure. At The Conclusion Of Our Production Test Period, Our Well Demonstrated An Average Flow Rate Of 1,312 Boe/d Consisting Of 2.9 Mmcf/d Of Gas And 819 Bbls/d Of Hydrocarbon Liquids. The Wellhead Condensate/oil Rate Was 624 Bbls/d With An Additional 195 Bbls/d Of C3+ Liquids Based On A Shallow Cut Extraction Process. The Condensate/oil Is 84% Of The Total Recoverable Liquids. Consistent With Industry Offset Pipestone/wembley Wells During Production Testing And Permanent Production, The Condensate/oil Yield Continued To Increase As Frac Load Water Was Being Recovered. Only 34% Of The Initial Load Fluid In Our 12-25 Well Has Been Recovered And We Anticipate That Liquid Rates Could Continue To Improve With Longer Production Times And The Installation Of Production Tubing To Optimize Wellbore Flow Dynamics. Options For Tie-in Of The 12-25 Well For Permanent Production, Including Connecting The Well Back To Our Glacier Gas Plant, Are Being Evaluated As Near Term Processing Capacity Is Limited In The Immediate Area.progress (39 Net Sections)our First Delineation Well Located At 13-31-77-09w6 Was Drilled To A Lateral Length Of 2,313 Meters And Was Fracture Stimulated With 44 Stages. The 13-31 Well Was Production Tested Over A 6 Day Period And Was Drawn Down To Less Than 40% Of The Reservoir Pressure While Flowing Up Production Casing. At The Conclusion Of The Test, The 13-31 Well Was Producing At An Average Rate Of 624 Boe/d Consisting Of 2.7 Mmcf/d Of Gas And 172 Bbls/d Of Hydrocarbon Liquids. The Wellhead Condensate Rate Was 75 Bbls/d With An Additional 97 Bbls/d Of C3+ Liquids Based On A Shallow Cut Extraction Process. The Condensate/oil Is 63% Of The Total Recoverable Liquids. Consistent With The Profile Of Producing Industry Offset Wells, The Flow Rate Of Our 13-31 Well Increased Throughout The Flow Period As Frac Load Water Was Being Recovered. Only 13% Of The Initial Load Fluid In Our Well Has Been Recovered And We Anticipate That The Production Rate Could Continue To Improve With Longer Production Times And Installation Of Production Tubing To Optimize Wellbore Flow Dynamics. Options For Tie-in Of The 13-31 Well For Permanent Production, Including Connecting The Well Back To Our Glacier Gas Plant, Is Being Evaluated As Near Term Processing Capacity Is Limited In The Immediate Area.*valhalla (40 Net Sections)at Valhalla, Design And Permitting Is Underway To Construct An Initial Facility Installation Which Includes 40 Mmcf/d Of Compression And Liquids Handling Equipment To Collect And Transport Natural Gas And Liquids For Processing At Our 100% Owned Glacier Gas Plant. This Facility Is Designed To Accommodate Liquids Rich Natural Gas Production From Our Recent Four Well Pad And Is Expandable To Accommodate Additional Growth. The Location Of This Facility Could Also Be Utilized As A Hub Where Future Production From Wembley And Progress Could Be Collected And Transported To Our Glacier Gas Plant Such That Netbacks And Investment Returns May Be Enhanced Due To The Benefits Realized Through Economies Of Scale And Integration With Our Established Industry Leading Low Cost Structure. This Facility Is Scheduled To Be Completed In The Fourth Quarter Of 2018.glacier Gas Plant Expansionthe Expansion Of Our 100% Owned Glacier Gas Plant Is On-track For Anticipated Completion In The Second Quarter Of 2018. Two Incremental Process Equipment Units Were Added As Part Of The Expansion Project To Begin Generating New Revenue And Provide More Flexibility And Efficiency In The Plant's Operation Due To Successful Wells In Our Adjacent Land Blocks. One Of The Process Units Added Was An Electric Power Generator Which Will Provide Surplus Electricity Sales (2.4 Mw) Into The Alberta Grid And The Other Process Unit Is A Heat Exchanger. Upon Completion, The Glacier Gas Plant Will Provide 400 Mmcf/d Of Raw Gas Processing Capability, Including 6,800 Bbls/d Of C3+ Liquids Extraction And Will Provide Additional Capacity To Accommodate Future Growth And Process Production From Our Adjacent Land Blocks.market Diversificationadvantage's Continued Market Diversification Initiatives Are Expected To Result In Revenue Exposure To Aeco Prices Of 4% And 28% For The First Quarter And Calendar Year 2018, Respectively. In Addition To Our Dawn, Ontario Market Exposure, Which Comprises Approximately 20% Of Our Current Production, We Have Recently Added Contracts To Transport Natural Gas To The Chicago/ventura U.s. Mid-west Markets. This Will Start In November 2018 With An Initial Volume Of 20,000 Mmbtu/d And Increases To An Annual Average Volume Of 35,000 Mmbtu/d In 2019 And 62,500 Mmbtu/d In 2020 At A Cost Of Approximately Us $1.15/mmbtu To Us $1.20/mmbtu.complementing Our Physical Market Diversification Efforts Are Other Financial Contracts Whereby We Have Both Fixed The Price On A Portion Of Our Natural Gas Production And Entered Basis Contracts To Diversify Revenue To The Henry Hub Market. For 2018, We Have Fixed The Price On 37% Of Our Estimated Natural Gas Production (91 Mmcf/d) At Cdn $3.21/mcf And 46 Mmcf/d For 2019 At Cdn $2.89/mcf. We Also Have 19 Mmcf/d (Approximately 8% Of 2018 Estimated Production) And 25 Mmcf/d Of Our 2019 Natural Gas Production Exposed To Henry Hub Prices With Basis Differentials Of Us $ 0.95/mmbtu And Us $ 0.90/mmbtu Respectively.looking Forwardour 2018 Production Guidance Includes A Slight Reduction In Production Volumes During The Second Quarter Of 2018 Followed By A Continued Increase Through The Second Half Of 2018 To Achieve Our Production Guidance Of 255 To 265 Mmcfe/d. The First Quarter Is Anticipated To Be 242 To 246 Mmcfe/d And Approximately 3% Lower In The Second Quarter Of 2018 To Accommodate A Short Plant Outage In Order To Complete The Integration Of New Equipment And Commissioning As Part Of The Glacier Gas Plant Expansion. Average Liquids Production For 2018 Is Targeted At 1,900 Bbls/d, Exiting The Year At 2,400 Bbls/d. Advantage's $175 Million Capital Program For 2018 Is Weighted Approximately 60% To The First Half Of The Year, With The Majority Of Spending Occurring During The First Quarter Including Completion Of The Glacier Gas Plant Expansion.advantage's Montney Development At Glacier Has Been Successfully Executed Since 2008 Based On Maintaining An Industry Leading Low Cost Structure, Preserving A Strong Balance Sheet And Preserving Operational And Financial Flexibility. These Factors, In Conjunction With An Increased Focus On Liquids Development In 2018 And Beyond Will Provide Advantage With The Ability To Respond Promptly And Responsibly To Market Conditions. We Wish To Thank All Of Our Shareholders And Our Board Of Directors For Their Ongoing Support And Most Importantly, All Of Our Peoplewe Look Forward To Reporting On Our Progress Through 2018.fourth Quarter And Full-year Operating And Financial Summarydisclaimer: The Table Has Been Omitted (The Document Can Be Viewed At Http://advantageog.mediaroom.com/2018-03-05-advantage-announces-2017-results-and-drilling-successes)production Increased 11% In The Fourth Quarter Of 2017 To A Record 245 Mmcfe/d (40,857 Boe/d) With 2017 Average Production Higher By 16% To 236 Mmcfe/d (39,315 Boe/d), As Compared To The Same Periods In 2016. Natural Gas Liquids Production Has Grown To 1,227 Bbls/d For The Fourth Quarter Of 2017, A 29% Increase From The Same Period In 2016 And Consisting Of Approximately 70% Condensate. Production Met Our Original Guidance Targets Despite Significant Third Party Pipeline Restrictions Which Impacted The Majority Of Western Canadian Producers Through 2017.funds From Operations Were $43.9 Million Or $0.24/share For The Quarter And $183.2 Million Or $0.99/share For The Year. Higher Production, Market Diversification Initiatives, A Proactive Hedging Strategy And Industry-leading Low Corporate Cash Costs Of $0.88/mcfe For The Year Resulted In Strong Funds From Operations.net Income Earned Of $95.0 Million Or $0.51/share For The Year And $21.4 Million Or $0.12/share For The Fourth Quarter Of 2017. Higher Production And Gains On Our Derivative Contracts Resulted In Net Income Throughout 2017. Excluding Unrealized Gains On Derivatives Of $17.2 Million And $73.3 Million In The Three Months And Year Ended December 31, 2017, Advantage Would Have Still Generated Significant Net Income.achieved A 3 Year All-in Capital Efficiency Of $15,333/boe/d. Advantage's 2017 All-in Capital Efficiency Of $17,000/boe/d Includes $80 Million For Our Glacier Gas Plant Expansion And $7 Million For Land Acquisitions, Which Results In A Capital Efficiency Of $11,100/boe/d When These Expenditures Are Excluded.continued Market Diversification Such That Only 28% Of Our Estimated 2018 Revenue Is Exposed To Aeco Prices. This Market Diversification Includes Fixed Price Hedges, Henry Hub And Dawn Market Exposures And Access To The Alliance Pipeline In 2018 Which Will Provide Further Opportunities Into The Mid-west U.s.the Corporation's Audited Consolidated Financial Statements For The Fiscal Year Ended December 31, 2017 Together With The Notes Thereto, And Management's Discussion And Analysis For The Year Ended December 31, 2017 Have Been Filed On Sedar And With The Sec And Are Available On The Corporation's Website At Http://www.advantageog.com/investors/financial-reports/2017-2. The Corporation's Audited Consolidated Financial Statements For The Fiscal Year Ended December 31, 2016 Are Also Available On The Corporation's Website Via The Same Webpage. Upon Request, Advantage Will Provide A Hard Copy Of Any Financial Reports Free Of Charge.this Document Has Footnotes And They May Be Found At: (Http://advantageog.mediaroom.com/2018-03-05-advantage-announces-2017-results-and-drilling-successes)source: Advantage Oil & Gascopyright 2017 Contify.com", "docTitle": "", "docDate": "2018-04-04 14:34:31.210" }, "meta": { "contentType": "text/raw", "processingVer": "AllMetadata", "serverVersion": "OneCalais_11.5-RELEASE:211", "stagsVer": "OneCalais_11.5-RELEASE-b3-2018-02-18_16:54:22", "submissionDate": "2018-04-04 14:34:29.401", "submitterCode": "0ca6a864-5659-789d-5f32-f365f695e757", "signature": "digestalg-1|zEL04evyU7DyGiNlr49JYJW3tl0=|dnNxtPhF7wWoS2E5oEz7xgMfh3h0z6dvWPx3pUUkGYxIxjEKeNHwsw==", "language": "English" } }, "http://d.opencalais.com/dochash-1/5f0a3b27-40f9-38fb-b356-c200a8f6d087/cat/1": { "_typeGroup": "topics", "forenduserdisplay": "false", "score": 1, "name": "Business_Finance" }, "http://d.opencalais.com/dochash-1/5f0a3b27-40f9-38fb-b356-c200a8f6d087/lid/DefaultLangId": { "_typeGroup": "language", "language": "http://d.opencalais.com/lid/DefaultLangId/English", "forenduserdisplay": "false", "permid": "505062" }, "http://d.opencalais.com/dochash-1/5f0a3b27-40f9-38fb-b356-c200a8f6d087/SocialTag/1": { "_typeGroup": "socialTag", "id": "http://d.opencalais.com/dochash-1/5f0a3b27-40f9-38fb-b356-c200a8f6d087/SocialTag/1", "socialTag": "http://d.opencalais.com/genericHasher-1/4beaa5de-f48b-3f40-975d-3ca888921f3e", "forenduserdisplay": "true", "name": "Fuel gas", "importance": "1", "originalValue": "Fuel gas" }, "http://d.opencalais.com/dochash-1/5f0a3b27-40f9-38fb-b356-c200a8f6d087/SocialTag/2": { "_typeGroup": "socialTag", "id": "http://d.opencalais.com/dochash-1/5f0a3b27-40f9-38fb-b356-c200a8f6d087/SocialTag/2", "socialTag": "http://d.opencalais.com/genericHasher-1/ca03e129-c3d1-34d7-b339-86167aae7d36", "forenduserdisplay": "true", "name": "Natural gas", "importance": "1", "originalValue": "Natural gas" }, "http://d.opencalais.com/dochash-1/5f0a3b27-40f9-38fb-b356-c200a8f6d087/SocialTag/3": { "_typeGroup": "socialTag", "id": "http://d.opencalais.com/dochash-1/5f0a3b27-40f9-38fb-b356-c200a8f6d087/SocialTag/3", "socialTag": "http://d.opencalais.com/genericHasher-1/dfebaaa7-9a05-3cf2-a2f4-075933a17b2b", "forenduserdisplay": "true", "name": "Oil well", "importance": "1", "originalValue": "Oil well" }, "http://d.opencalais.com/dochash-1/5f0a3b27-40f9-38fb-b356-c200a8f6d087/SocialTag/4": { "_typeGroup": "socialTag", "id": "http://d.opencalais.com/dochash-1/5f0a3b27-40f9-38fb-b356-c200a8f6d087/SocialTag/4", "socialTag": "http://d.opencalais.com/genericHasher-1/412d2c87-2ead-391a-ae44-6add965d8ada", "forenduserdisplay": "true", "name": "Economy", "importance": "2", "originalValue": "Economy" }, "http://d.opencalais.com/dochash-1/5f0a3b27-40f9-38fb-b356-c200a8f6d087/SocialTag/5": { "_typeGroup": "socialTag", "id": "http://d.opencalais.com/dochash-1/5f0a3b27-40f9-38fb-b356-c200a8f6d087/SocialTag/5", "socialTag": "http://d.opencalais.com/genericHasher-1/3a9f6828-4fee-38d5-addf-1bf9234aee44", "forenduserdisplay": "true", "name": "Science and technology", "importance": "2", "originalValue": "Science and technology" }, "http://d.opencalais.com/dochash-1/5f0a3b27-40f9-38fb-b356-c200a8f6d087/SocialTag/6": { "_typeGroup": "socialTag", "id": "http://d.opencalais.com/dochash-1/5f0a3b27-40f9-38fb-b356-c200a8f6d087/SocialTag/6", "socialTag": "http://d.opencalais.com/genericHasher-1/623b01d7-2221-3867-ad97-cdf343a743f4", "forenduserdisplay": "true", "name": "Technology", "importance": "2", "originalValue": "Technology" }, "http://d.opencalais.com/dochash-1/5f0a3b27-40f9-38fb-b356-c200a8f6d087/Industry/1": { "_typeGroup": "industry", "forenduserdisplay": "false", "name": "Gold Mining", "rcscode": "B:1079", "permid": "4294951922", "relevance": 0.2 }, "http://d.opencalais.com/dochash-1/5f0a3b27-40f9-38fb-b356-c200a8f6d087/Industry/2": { "_typeGroup": "industry", "forenduserdisplay": "false", "name": "Closed End Funds", "rcscode": "B:1694", "permid": "4294951307", "relevance": 0.8 }, "http://d.opencalais.com/dochash-1/5f0a3b27-40f9-38fb-b356-c200a8f6d087/Industry/3": { "_typeGroup": "industry", "forenduserdisplay": "false", "name": "Natural Gas Distribution", "rcscode": "B:1831", "permid": "4294951170", "relevance": 0.2 }, "http://d.opencalais.com/dochash-1/5f0a3b27-40f9-38fb-b356-c200a8f6d087/ComponentVersions": { "_typeGroup": "versions", "version": [ "DIY-Categorization-fnr-TRCS-prcng_3:20171117095241:20171117095241", "DIY-Categorization-fnr-TRCS-curint-News:20180221133342:20180221133342", "DIY-Categorization-fnr-TRCS-capx:20170627191152:20170627191152", "DIY-Categorization-fnr-TRCS-abs-News:20180321093043:20180321093043", "DIY-Categorization-fnr-TRCS-cstcut_new-News:20180301140156:20180301140156", "DIY-Categorization-fnr-TRCS-margnu:20171117095324:20171117095324", "Deals Index:201804041416:201804041416", "DIY-Categorization-fnr-TRCS-indx_stsale:20170323110805:20170323110805", "DIY-Categorization-fnr-TRCS-comptn:20170621141739:20170621141739", "index-refineries:201804011021:201804011021", "DIY-Categorization-fnr-TRCS-regs_buyb_new:20170509091609:20170509091609", "DIY-Categorization-fnr-TRCS-int___INT-News:20180326113056:20180326113056", "config-physicalAssets-powerStations:743:743", "NextTags:OneCalais_11.5-RELEASE:211", "SpanishIM:OneCalais_11.5-RELEASE:38", "DIY-Categorization-fnr-TRCS-infl-News:20180206095852:20180206095852", "DIY-Categorization-fnr-TRCS-newjbs:20180124163802:20180124163802", "DIY-Categorization-fnr-TRCS-dis:20170418132337:20170418132337", "DIY-Categorization-fnr-TRCS-revdrv2-News:20180202125843:20180202125843", "DIY-Categorization-fnr-TRCS-splitb_r1:20170329082516:20170329082516", "DIY-Categorization-fnr-TRCS-alu-News:20180314130406:20180314130406", "DIY-Categorization-fnr-TRCS-esgenv_2-News:20180202131300:20180202131300", "DIY-Categorization-fnr-TRCS-margnd_2:20171117095121:20171117095121", "DIY-Categorization-fnr-TRCS-change_of_cfo_joel_res-Research:20180315092841:20180315092841", "config-sca-DataPackage:50:50", "DIY-Categorization-fnr-TRCS-mergers___acquisitions__joel_rch-Research:20180322100020:20180322100020", "config-companyNe:765:765", "DIY-Categorization-fnr-TRCS-acb:20170502102348:20170502102348", "DIY-Categorization-fnr-TRCS-stsale_new-News:20180302131833:20180302131833", "DIY-Categorization-fnr-TRCS-hosal_jayasimha-News:20180320092027:20180320092027", "DIY-Categorization-fnr-TRCS-levrge:20170621122109:20170621122109", "DIY-Categorization-fnr-TRCS-hedge_list1:20170625000000:20170625000000", "DIY-Categorization-fnr-TRCS-corporate_inventory_rama_rch___INVTRY-Research:20180329065542:20180329065542", "SECHeaderMetadataIM:OneCalais_11.5-RELEASE:38", "DIY-Categorization-fnr-TRCS-esggov-News:20180301091656:20180301091656", "DIY-Categorization-fnr-TRCS-sales1:20171219091829:20171219091829", "config-refreshableDIY:1:1", "DIY-Categorization-fnr-TRCS-crycur:20171121113558:20171121113558", "DIY-Categorization-fnr-TRCS-rmrmrg:20171204112525:20171204112525", "DIY-Categorization-fnr-TRCS-capital_expenditure_rama_rch2-Research:20180305132538:20180305132538", "DIY-Categorization-fnr-TRCS-frxrte:20171229123536:20171229123536", "DIY-Categorization-fnr-TRCS-esgsoc_2-News:20180315093602:20180315093602", "People Index:201804041156:201804041156", "DIY-Categorization-fnr-TRCS-mons___MONS-News:20180404103759:20180404103759", "DIY-Categorization-fnr-TRCS-awlq:20170331124441:20170331124441", "DIY-Categorization-fnr-TRCS-corporate_valuation_rama_rch___CVALU-Research:20180403102035:20180403102035", "DIY-Categorization-fnr-TRCS-market_share_rsch_joel_new___MKTSHR-Research:20180403070617:20180403070617", "config-negativeSignature:743:743", "DIY-Categorization-fnr-TRCS-fake1_monop_bnkcap_new:20170405133257:20170405133257", "Dial4J:OneCalais_11.5-RELEASE:38", "DIY-Categorization-fnr-TRCS-share_buybacks_repurchase_ram_rh-Research:20180322095215:20180322095215", "AutocoderRuntimeIM:OneCalais_11.5-RELEASE:38", "DIY-Categorization-fnr-TRCS-dbtr_new:20170315123740:20170315123740", "DIY-Categorization-fnr-TRCS-scale_2:20171130072915:20171130072915", "DIY-Categorization-fnr-TRCS-dbulk___DBULK-News:20180403110302:20180403110302", "DIY-Categorization-fnr-TRCS-gdp-News:20180321130548:20180321130548", "OA Override:765:765", "DIY-Categorization-fnr-TRCS-hrgt:20170427081548:20170427081548", "DIY-Categorization-fnr-TRCS-xpand:20170323144646:20170323144646", "DIY-Categorization-fnr-TRCS-kycterror-News:20180223164257:20180223164257", "DIY-Categorization-fnr-TRCS-leverage_ratios_rama_rch-Research:20180305132725:20180305132725", "DIY-Categorization-fnr-TRCS-same_store_sales_sai_rch-Research:20180320084305:20180320084305", "DIY-Categorization-fnr-TRCS-bonus_share_issues_sai_rch-Research:20180305132618:20180305132618", "DIY-Categorization-fnr-TRCS-resass-News:20180208130324:20180208130324", "DIY-Categorization-fnr-TRCS-allcemrgdvst2:20170424130000:20170424130000", "DIY-Categorization-fnr-TRCS-lead1-News:20180321121644:20180321121644", "DIY-Categorization-fnr-TRCS-ordr:20170313151239:20170313151239", "People Override:743:743", "DIY-Categorization-fnr-TRCS-seasns_kamila-News:20180320120211:20180320120211", "DIY-Categorization-fnr-TRCS-change_of_ceo_ram_rch___CEO1-Research:20180403103028:20180403103028", "DIY-Categorization-fnr-TRCS-hrgt_recll:20170522120000:20170522120000", "index-company-oa3:201804032256:201804032256", "DIY-Categorization-fnr-TRCS-rawm___RAWM-News:20180403083541:20180403083541", "index-vessels:201803312345:201803312345", "DIY-Categorization-fnr-TRCS-brib_r1:20170329090629:20170329090629", "DIY-Categorization-fnr-TRCS-mplt___MPLT-News:20180327111715:20180327111715", "DIY-Categorization-fnr-TRCS-shareholder_activism_rama_rch-Research:20180320142730:20180320142730", "DIY-Categorization-fnr-TRCS-cvalu:20171212133524:20171212133524", "DIY-Categorization-fnr-TRCS-csent-News:20180314134456:20180314134456", "BrokerResearchIM:OneCalais_11.5-RELEASE:38", "DIY-Categorization-fnr-TRCS-company_cost_reduction_ram_rch2-Research:20180320152742:20180320152742", "config-forEndUserDisplay:3:3", "config-refineries:743:743", "DIY-Categorization-fnr-TRCS-cdo2-News:20180315084530:20180315084530", "DIY-Categorization-fnr-TRCS-prdlch-News:20180201133354:20180201133354", "DIY-Categorization-fnr-TRCS-strategic_combinations_joel_rch-Research:20180315092813:20180315092813", "DIY-Categorization-fnr-TRCS-ipr-News:20180319134217:20180319134217", "DIY-Categorization-fnr-TRCS-fapm:20170713144316:20170713144316", "DIY-Categorization-fnr-TRCS-class:20170315123207:20170315123207", "config-cse:765:765", "OneCalaisIM:OneCalais_11.5-RELEASE:38", "DIY-Categorization-fnr-TRCS-isu_dat_r:20170405124144:20170405124144", "DIY-Categorization-fnr-TRCS-cnsl_sisu:20170321144134:20170321144134", "DIY-Categorization-fnr-TRCS-newjbs-News:20180123114120:20180123114120", "DIY-Categorization-fnr-TRCS-shract_r1:20170412111808:20170412111808", "config-vessels:743:743", "DIY-Categorization-fnr-TRCS-product_shipments_rashmi_rch2-Research:20180313094806:20180313094806", "OneCalais:OneCalais_11.5-RELEASE:211", "DIY-Categorization-fnr-TRCS-invtry_09_25_2017:20171120093416:20171120093416", "DIY-Categorization-fnr-TRCS-mktshr2:20170705120412:20170705120412", "DIY-RCS-fnr-TRCS-cavs:4:4", "DIY-Categorization-fnr-TRCS-divestitures_spin_offs_rash_rch-Research:20180305132659:20180305132659", "DIY-Categorization-fnr-TRCS-eub___EUB-News:20180327093517:20180327093517", "DIY-Categorization-fnr-TRCS-blktrd_r1:20171116075645:20171116075645", "DIY-Categorization-fnr-TRCS-trd_tax:20170309132522:20170309132522", "DIY-Categorization-fnr-TRCS-sov_2:20170522130956:20170522130956", "DIY-Categorization-fnr-TRCS-bons:20170406103713:20170406103713", "DIY-Categorization-fnr-TRCS-racr___RACR-News:20180404134359:20180404134359", "DIY-Categorization-fnr-TRCS-corruption___bribery___joel_rch-Research:20180319102344:20180319102344", "DIY-Categorization-fnr-TRCS-exchange_rate_impact_rama_rsh-Research:20180312091507:20180312091507", "DIY-Categorization-fnr-TRCS-bankruptcy_insolvency_rsch_joel-Research:20180315095938:20180315095938", "DIY-Categorization-fnr-TRCS-blkchn_4-News:20180123105513:20180123105513", "DIY-Categorization-fnr-TRCS-segrev:20171117133125:20171117133125", "DIY-Categorization-tms-TRCS-sanity_tms_auto_publish___CEO1-News:20180325093931:20180325093931", "DIY-Categorization-fnr-TRCS-hrgt_namec:20170329090731:20170329090731", "DIY-Categorization-fnr-TRCS-change_of_president_joel_rch___PRES1-Research:20180402085923:20180402085923", "DIY-RCS-fnr-TRCS-nd:3:3", "DIY-Categorization-fnr-TRCS-stx:20170530123138:20170530123138", "DIY-Categorization-fnr-TRCS-pmi-News:20180214153232:20180214153232", "config-physicalAssets-mines:743:743", "SocialTags Index:201804031201:201804031201", "BlackList:765:765", "DIY-Categorization-fnr-TRCS-shpmnt_new2:20171116121809:20171116121809", "DIY-Categorization-fnr-TRCS-gol-News:20180319131232:20180319131232", "DIY-Categorization-fnr-TRCS-crptax:20171117095403:20171117095403", "DIY-Categorization-fnr-TRCS-cppr-News:20180315144023:20180315144023", "index-ports:201804010416:201804010416", "FrenchIM:OneCalais_11.5-RELEASE:38", "config-physicalAssets-ports:743:743", "DIY-Categorization-fnr-TRCS-ream:20170529065740:20170529065740", "DIY-Categorization-fnr-TRCS-chld:20170524084254:20170524084254", "DIY-Categorization-fnr-TRCS-allce:20170323145654:20170323145654", "DIY-Categorization-fnr-TRCS-medreg:20170508120210:20170508120210", "DIY-Categorization-fnr-TRCS-equity_stakes_rama_rch___STK-Research:20180329064332:20180329064332", "config-drugs:743:743", "DIY-Categorization-fnr-TRCS-exrsks:20171129184952:20171129184952" ] }, "http://d.opencalais.com/comphash-1/2d7b8a2f-346c-3e58-a331-76ffe9626934": { "_typeGroup": "entities", "_type": "Company", "forenduserdisplay": "false", "name": "Operations.net", "nationality": "N/A", "confidencelevel": "0.417", "recognizedas": "name", "_typeReference": "http://s.opencalais.com/1/type/em/e/Company", "instances": [ { "detection": "[For The Year Resulted In Strong Funds From ]Operations.net[ Income Earned Of $95.0 Million Or $0.51/share]", "prefix": "For The Year Resulted In Strong Funds From ", "exact": "Operations.net", "suffix": " Income Earned Of $95.0 Million Or $0.51/share", "offset": 10516, "length": 14 } ], "relevance": 0.2, "confidence": { "statisticalfeature": "0.755", "dblookup": "0.0", "resolution": "0.0", "aggregate": "0.417" } }, "http://d.opencalais.com/comphash-1/294a6c04-9d86-36b7-bf5a-fe94ba821b92": { "_typeGroup": "entities", "_type": "Company", "forenduserdisplay": "false", "name": "Advantage", "confidencelevel": "0.758", "recognizedas": "name", "_typeReference": "http://s.opencalais.com/1/type/em/e/Company", "instances": [ { "detection": "[And Financial Results Summary(please Refer To ]Advantage['s Press Release On February 12, 2018 Which]", "prefix": "And Financial Results Summary(please Refer To ", "exact": "Advantage", "suffix": "'s Press Release On February 12, 2018 Which", "offset": 56, "length": 9 }, { "detection": "[Development Potential That Could Be Realized On ]Advantage['s Land Blocks.wembley (31 Net]", "prefix": "Development Potential That Could Be Realized On ", "exact": "Advantage", "suffix": "'s Land Blocks.wembley (31 Net", "offset": 2220, "length": 9 }, { "detection": "[1,900 Bbls/d, Exiting The Year At 2,400 Bbls/d. ]Advantage['s $175 Million Capital Program For 2018 Is]", "prefix": "1,900 Bbls/d, Exiting The Year At 2,400 Bbls/d. ", "exact": "Advantage", "suffix": "'s $175 Million Capital Program For 2018 Is", "offset": 8568, "length": 9 }, { "detection": "[Development In 2018 And Beyond Will Provide ]Advantage[ With The Ability To Respond Promptly And]", "prefix": "Development In 2018 And Beyond Will Provide ", "exact": "Advantage", "suffix": " With The Ability To Respond Promptly And", "offset": 9143, "length": 9 }, { "detection": "[Three Months And Year Ended December 31, 2017, ]Advantage[ Would Have Still Generated Significant Net]", "prefix": "Three Months And Year Ended December 31, 2017, ", "exact": "Advantage", "suffix": " Would Have Still Generated Significant Net", "offset": 10882, "length": 9 }, { "detection": "[ Year All-in Capital Efficiency Of $15,333/boe/d. ]Advantage['s 2017 All-in Capital Efficiency Of]", "prefix": " Year All-in Capital Efficiency Of $15,333/boe/d. ", "exact": "Advantage", "suffix": "'s 2017 All-in Capital Efficiency Of", "offset": 11004, "length": 9 }, { "detection": "[Website Via The Same Webpage. Upon Request, ]Advantage[ Will Provide A Hard Copy Of Any Financial]", "prefix": "Website Via The Same Webpage. Upon Request, ", "exact": "Advantage", "suffix": " Will Provide A Hard Copy Of Any Financial", "offset": 12118, "length": 9 } ], "relevance": 0.8, "resolutions": [ { "name": "Redwood Energy Income Fund", "permid": "4297137809", "primaryric": "AOG_u.TO", "ispublic": "true", "commonname": "Redwood Energy", "score": 0.25683078, "id": "https://permid.org/1-4297137809", "ticker": "AOG.UN" } ], "confidence": { "statisticalfeature": "0.837", "dblookup": "0.0", "resolution": "0.25683078", "aggregate": "0.758" } }, "http://d.opencalais.com/genericHasher-1/e984ebc9-975d-3cd0-b615-8f9fd463af03": { "_typeGroup": "entities", "_type": "Facility", "forenduserdisplay": "false", "name": "Including Connecting The Well Back To Our Glacier Gas Plant", "_typeReference": "http://s.opencalais.com/1/type/em/e/Facility", "instances": [ { "detection": "[Of The 12-25 Well For Permanent Production, ]Including Connecting The Well Back To Our Glacier Gas Plant[, Are Being Evaluated As Near Term Processing]", "prefix": "Of The 12-25 Well For Permanent Production, ", "exact": "Including Connecting The Well Back To Our Glacier Gas Plant", "suffix": ", Are Being Evaluated As Near Term Processing", "offset": 3512, "length": 59 }, { "detection": "[Of The 13-31 Well For Permanent Production, ]Including Connecting The Well Back To Our Glacier Gas Plant[, Is Being Evaluated As Near Term Processing]", "prefix": "Of The 13-31 Well For Permanent Production, ", "exact": "Including Connecting The Well Back To Our Glacier Gas Plant", "suffix": ", Is Being Evaluated As Near Term Processing", "offset": 4811, "length": 59 } ], "relevance": 0.2 }, "http://d.opencalais.com/genericHasher-1/1133dfad-b421-3cb4-8e32-f42fc6787120": { "_typeGroup": "entities", "_type": "Facility", "forenduserdisplay": "false", "name": "Owned Glacier Gas Plant", "_typeReference": "http://s.opencalais.com/1/type/em/e/Facility", "instances": [ { "detection": "[Gas And Liquids For Processing At Our 100% ]Owned Glacier Gas Plant[. This Facility Is Designed To Accommodate]", "prefix": "Gas And Liquids For Processing At Our 100% ", "exact": "Owned Glacier Gas Plant", "suffix": ". This Facility Is Designed To Accommodate", "offset": 5224, "length": 23 } ], "relevance": 0.2 }, "http://d.opencalais.com/genericHasher-1/7005e85c-9738-3e8e-9da7-5a10890b0914": { "_typeGroup": "entities", "_type": "URL", "forenduserdisplay": "false", "name": "Http://advantageog.mediaroom.com/2018-03-05-advantage-announces-2017-results-and-drilling-successes)source", "_typeReference": "http://s.opencalais.com/1/type/em/e/URL", "instances": [ { "detection": "[Has Footnotes And They May Be Found At: (]Http://advantageog.mediaroom.com/2018-03-05-advantage-announces-2017-results-and-drilling-successes)source[: Advantage Oil & Gascopyright 2017]", "prefix": "Has Footnotes And They May Be Found At: (", "exact": "Http://advantageog.mediaroom.com/2018-03-05-advantage-announces-2017-results-and-drilling-successes)source", "suffix": ": Advantage Oil & Gascopyright 2017", "offset": 12248, "length": 106 } ], "relevance": 0.2 }, "http://d.opencalais.com/genericHasher-1/9467eaf4-16ea-3544-a48a-e546a31791c7": { "_typeGroup": "entities", "_type": "URL", "forenduserdisplay": "false", "name": "Http://www.advantageog.com/investors/financial-reports/2017-2", "_typeReference": "http://s.opencalais.com/1/type/em/e/URL", "instances": [ { "detection": "[Are Available On The Corporation's Website At ]Http://www.advantageog.com/investors/financial-reports/2017-2[. The Corporation's Audited Consolidated]", "prefix": "Are Available On The Corporation's Website At ", "exact": "Http://www.advantageog.com/investors/financial-reports/2017-2", "suffix": ". The Corporation's Audited Consolidated", "offset": 11867, "length": 61 } ], "relevance": 0.2 }, "http://d.opencalais.com/genericHasher-1/157299a1-3fa3-3e0f-a78b-696d59092f02": { "_typeGroup": "entities", "_type": "Region", "forenduserdisplay": "false", "name": "west U.s.", "_typeReference": "http://s.opencalais.com/1/type/em/e/Region", "instances": [ { "detection": "[Will Provide Further Opportunities Into The Mid-]west U.s.[the Corporation's Audited Consolidated Financial]", "prefix": "Will Provide Further Opportunities Into The Mid-", "exact": "west U.s.", "suffix": "the Corporation's Audited Consolidated Financial", "offset": 11551, "length": 9 }, { "detection": "[Will Provide Further Opportunities Into The Mid-]west U.s.[the Corporation's Audited Consolidated Financial]", "prefix": "Will Provide Further Opportunities Into The Mid-", "exact": "west U.s.", "suffix": "the Corporation's Audited Consolidated Financial", "offset": 11551, "length": 9 } ], "relevance": 0.2 }, "http://d.opencalais.com/pershash-1/9c1a569d-d2d5-3a95-9fb4-9fda90e7207a": { "_typeGroup": "entities", "_type": "Person", "forenduserdisplay": "true", "name": "Wells During", "persontype": "N/A", "nationality": "N/A", "confidencelevel": "0.6", "firstname": "Wells", "lastname": "During", "commonname": "Wells During", "_typeReference": "http://s.opencalais.com/1/type/em/e/Person", "permid": "https://permid.org/1-404011", "instances": [ { "detection": "[With Industry Offset Pipestone/wembley ]Wells During[ Production Testing And Permanent Production, The]", "prefix": "With Industry Offset Pipestone/wembley ", "exact": "Wells During", "suffix": " Production Testing And Permanent Production, The", "offset": 3063, "length": 12 } ], "relevance": 0.2, "confidence": { "statisticalfeature": "0.724", "dblookup": "0.0", "resolution": "0.0", "aggregate": "0.6" } }, "http://d.opencalais.com/genericHasher-1/ab276e46-a0eb-3c8c-8203-d2aad3c129cf": { "_typeGroup": "entities", "_type": "Organization", "forenduserdisplay": "false", "name": "The Alliance", "organizationtype": "political party", "nationality": "N/A", "_typeReference": "http://s.opencalais.com/1/type/em/e/Organization", "permid": "https://permid.org/1-404010", "instances": [ { "detection": "[Hub And Dawn Market Exposures And Access To ]The Alliance[ Pipeline In 2018 Which Will Provide Further]", "prefix": "Hub And Dawn Market Exposures And Access To ", "exact": "The Alliance", "suffix": " Pipeline In 2018 Which Will Provide Further", "offset": 11467, "length": 12 } ], "relevance": 0.2 }, "http://d.opencalais.com/genericHasher-1/7f9deb78-0be5-3933-b8ac-e0f415ced3a2": { "_typeGroup": "entities", "_type": "Organization", "forenduserdisplay": "false", "name": "U.S. Securities and Exchange Commission", "organizationtype": "governmental civilian", "nationality": "American", "_typeReference": "http://s.opencalais.com/1/type/em/e/Organization", "permid": "https://permid.org/1-404010", "instances": [ { "detection": "[31, 2017 Have Been Filed On Sedar And With The ]Sec[ And Are Available On The Corporation's Website]", "prefix": "31, 2017 Have Been Filed On Sedar And With The ", "exact": "Sec", "suffix": " And Are Available On The Corporation's Website", "offset": 11813, "length": 3 } ], "relevance": 0.2 }, "http://d.opencalais.com/genericHasher-1/31ec6404-85fe-33f5-af02-cb37fec6b170": { "_typeGroup": "entities", "_type": "IndustryTerm", "forenduserdisplay": "false", "name": "oil", "_typeReference": "http://s.opencalais.com/1/type/em/e/IndustryTerm", "instances": [ { "detection": "[Of Hydrocarbon Liquids. The Wellhead Condensate/]oil[ Rate Was 624 Bbls/d With An Additional 195]", "prefix": "Of Hydrocarbon Liquids. The Wellhead Condensate/", "exact": "oil", "suffix": " Rate Was 624 Bbls/d With An Additional 195", "offset": 2841, "length": 3 }, { "detection": "[ A Shallow Cut Extraction Process. The Condensate/]oil[ Is 84% Of The Total Recoverable Liquids.]", "prefix": " A Shallow Cut Extraction Process. The Condensate/", "exact": "oil", "suffix": " Is 84% Of The Total Recoverable Liquids.", "offset": 2968, "length": 3 }, { "detection": "[ Testing And Permanent Production, The Condensate/]oil[ Yield Continued To Increase As Frac Load Water]", "prefix": " Testing And Permanent Production, The Condensate/", "exact": "oil", "suffix": " Yield Continued To Increase As Frac Load Water", "offset": 3136, "length": 3 }, { "detection": "[ A Shallow Cut Extraction Process. The Condensate/]oil[ Is 63% Of The Total Recoverable Liquids.]", "prefix": " A Shallow Cut Extraction Process. The Condensate/", "exact": "oil", "suffix": " Is 63% Of The Total Recoverable Liquids.", "offset": 4292, "length": 3 } ], "relevance": 0.2 }, "http://d.opencalais.com/comphash-1/24c2a916-8a1a-3c6c-8378-9facd99f55da": { "_typeGroup": "entities", "_type": "Company", "forenduserdisplay": "false", "name": "Term Processing Capacity Is Limited", "nationality": "N/A", "confidencelevel": "0.69", "recognizedas": "name", "_typeReference": "http://s.opencalais.com/1/type/em/e/Company", "instances": [ { "detection": "[Glacier Gas Plant, Are Being Evaluated As Near ]Term Processing Capacity Is Limited[ In The Immediate Area.progress (39 Net]", "prefix": "Glacier Gas Plant, Are Being Evaluated As Near ", "exact": "Term Processing Capacity Is Limited", "suffix": " In The Immediate Area.progress (39 Net", "offset": 3601, "length": 35 }, { "detection": "[Glacier Gas Plant, Is Being Evaluated As Near ]Term Processing Capacity Is Limited[ In The Immediate Area.*valhalla (40 Net]", "prefix": "Glacier Gas Plant, Is Being Evaluated As Near ", "exact": "Term Processing Capacity Is Limited", "suffix": " In The Immediate Area.*valhalla (40 Net", "offset": 4899, "length": 35 } ], "relevance": 0.2, "confidence": { "statisticalfeature": "0.848", "dblookup": "0.0", "resolution": "0.0", "aggregate": "0.69" } }, "http://d.opencalais.com/genericHasher-1/86aff5a5-ea26-3f03-a973-1a2c397caff6": { "_typeGroup": "entities", "_type": "Product", "forenduserdisplay": "false", "name": "Four Well Pad", "producttype": "Other", "_typeReference": "http://s.opencalais.com/1/type/em/e/Product", "instances": [ { "detection": "[Rich Natural Gas Production From Our Recent ]Four Well Pad[ And Is Expandable To Accommodate Additional]", "prefix": "Rich Natural Gas Production From Our Recent ", "exact": "Four Well Pad", "suffix": " And Is Expandable To Accommodate Additional", "offset": 5342, "length": 13 } ], "relevance": 0.2 }, "http://d.opencalais.com/genericHasher-1/03ff2f32-7d79-3042-a299-2010505bc8fc": { "_typeGroup": "entities", "_type": "City", "forenduserdisplay": "true", "name": "Chicago", "_typeReference": "http://s.opencalais.com/1/type/em/e/City", "instances": [ { "detection": "[Added Contracts To Transport Natural Gas To The ]Chicago[/ventura U.s. Mid-west Markets. This Will Start]", "prefix": "Added Contracts To Transport Natural Gas To The ", "exact": "Chicago", "suffix": "/ventura U.s. Mid-west Markets. This Will Start", "offset": 7065, "length": 7 } ], "relevance": 0.2, "resolutions": [ { "name": "Chicago,Illinois,United States", "shortname": "Chicago", "latitude": "41.85", "longitude": "-87.65", "containedbystate": "Illinois", "containedbycountry": "United States", "rcscode": "G:11Y" } ] }, "http://d.opencalais.com/genericHasher-1/a54ac18b-a956-3b5c-b235-0609ca899305": { "_typeGroup": "entities", "_type": "Country", "forenduserdisplay": "true", "name": "United States", "resolutions": [ { "name": "United States", "shortname": "United States", "latitude": "40.4230003233", "longitude": "-98.7372244786", "rcscode": "G:6J", "permid": "100319" } ], "_typeReference": "http://s.opencalais.com/1/type/em/e/Country", "instances": [ { "detection": "[Provide Further Opportunities Into The Mid-west ]U.s.[the Corporation's Audited Consolidated Financial]", "prefix": "Provide Further Opportunities Into The Mid-west ", "exact": "U.s.", "suffix": "the Corporation's Audited Consolidated Financial", "offset": 11556, "length": 4 } ], "relevance": 0.2 }, "http://d.opencalais.com/comphash-1/0da11470-b39f-3346-817d-c6ea6de32f3e": { "_typeGroup": "entities", "_type": "Company", "forenduserdisplay": "false", "name": "Valhalla", "confidencelevel": "0.464", "recognizedas": "name", "resolutions": [ { "name": "Valhalla", "permid": "5035166520", "ispublic": "false", "commonname": "Valhalla", "score": 0.67713135, "id": "https://permid.org/1-5035166520", "ticker": "VH.H" } ], "_typeReference": "http://s.opencalais.com/1/type/em/e/Company", "instances": [ { "detection": "[ The Immediate Area.*valhalla (40 Net Sections)at ]Valhalla[, Design And Permitting Is Underway To Construct]", "prefix": " The Immediate Area.*valhalla (40 Net Sections)at ", "exact": "Valhalla", "suffix": ", Design And Permitting Is Underway To Construct", "offset": 4987, "length": 8 }, { "detection": "[Capacity Is Limited In The Immediate Area.*]valhalla[ (40 Net Sections)at Valhalla, Design And]", "prefix": "Capacity Is Limited In The Immediate Area.*", "exact": "valhalla", "suffix": " (40 Net Sections)at Valhalla, Design And", "offset": 4958, "length": 8 } ], "relevance": 0.2, "confidence": { "statisticalfeature": "0.71", "dblookup": "0.0", "resolution": "0.67713135", "aggregate": "0.464" } }, "http://d.opencalais.com/genericHasher-1/ba259d44-8930-332a-aa86-0a435d2965d6": { "_typeGroup": "entities", "_type": "Facility", "forenduserdisplay": "false", "name": "Facility Is Scheduled To Be Completed In The Fourth Quarter", "_typeReference": "http://s.opencalais.com/1/type/em/e/Facility", "instances": [ { "detection": "[Industry Leading Low Cost Structure. This ]Facility Is Scheduled To Be Completed In The Fourth Quarter[ Of 2018.glacier Gas Plant Expansionthe Expansion]", "prefix": "Industry Leading Low Cost Structure. This ", "exact": "Facility Is Scheduled To Be Completed In The Fourth Quarter", "suffix": " Of 2018.glacier Gas Plant Expansionthe Expansion", "offset": 5773, "length": 59 } ], "relevance": 0.2 }, "http://d.opencalais.com/genericHasher-1/7ba8affd-15dd-3ab0-a3ad-6bef9ac62aa0": { "_typeGroup": "relations", "_type": "CompanyProduct", "forenduserdisplay": "false", "producttype": "Other", "_typeReference": "http://s.opencalais.com/1/type/em/r/CompanyProduct", "company": "http://d.opencalais.com/comphash-1/24c2a916-8a1a-3c6c-8378-9facd99f55da", "product": "http://d.opencalais.com/genericHasher-1/86aff5a5-ea26-3f03-a973-1a2c397caff6", "instances": [ { "detection": "[Liquids Rich Natural Gas Production From ]Our Recent Four Well Pad[ And Is Expandable To Accommodate Additional]", "prefix": "Liquids Rich Natural Gas Production From ", "exact": "Our Recent Four Well Pad", "suffix": " And Is Expandable To Accommodate Additional", "offset": 5331, "length": 24 } ] } }
Which has no mention of Advantage's PermID: 4295860402. Furthermore, when I call the API in Python I get an even more different result, which does not have Advantage's or Valhalla's PermIDs, but rather a result with a company called Wembley's with its PermID!
Very strange... if anyone knows a fix that would be great.
