Java EMA: Problem subscribing to realtime and delayed ticker at same time
I'm able to subscribe to delayed names like /IBM.N and /SPY.P, but if I try to subscript to SPY.P, I cannot subsequently subscribe to /SPY.P when the user I'm subscribing with isn't permissioned for real-time.
What I'm seeing is that I try to subscribe to "SPY.P", and I get back a NotAuthorized status in onStatusMsg. When I receive that, I call OmmConsumer.unregister(handle) to unregister the SPY.P subscription, and then attempt to subscribe to "/SPY.P".
However, the consumer thinks I'm just trying to subscribe to SPY.P - I get a second NotAuthorized error and msg.getName() is "SPY.P", whereas it should be "/SPY.P". How can I successfully do this, or do I just have to do something like open up a second consumer for delayed subscriptions?
(I did try creating a second OmmConsumer just for delayed subscriptions, as a workaround, but then the delayed subscription on the second consumer results in a "Received an item event without user specified pointer or stream info" ItemCallbackException.
Looking for any advice on how to handle this.
Thanks,
Shawn
Hello @shawn11
If the problem still occurs, please send us your source code as requested by Jirapongse. This will allow us to help you to investigate the problem.
@shawn11
From my test, this problem has been solved in Elektron SDK - Java - 1.1.1.E2. You can download it from here.
Please try it and let us know the result.
@shawn11
Please kindly update the progress of this issue.
If you still see the problem, please share the code. Therefore, we can use it to replicate the issue.
@jirapongse.phuriphanvichai I'm still getting the same error in 1.1.1.E2
@shawn11
My code may be too simple. Please see the attached file. consumerjava.txt
If I use EMA Java 1.1.1.E2, the output is:
StatusMsg
    streamId="5"
    domain="MarketPrice Domain"
    state="Closed / Suspect / Not entitled / 'Access Denied: User req to IDN for Exch - NYS'"
    name="IBM.N"
    nameType="1"
    serviceId="2115"
    serviceName="API_ELEKTRON_EPD_RSSL"
StatusMsgEnd
RefreshMsg
    streamId="6"
    solicited
    RefreshComplete
    state="Open / Ok / None / 'All is well'"
    itemGroup="00 01"
    permissionData="03 08 43 40 17 c0"
    name="/IBM.N"
    nameType="1"
    serviceId="2115"
    Payload dataType="FieldList"
From the output, it can subscribe to /IBM.N when IBM.N is access denied.
However, if I use the same code with EMA Java 1.1.1.L1, I get this output.
StatusMsg
    streamId="5"
    name="IBM.N"
    nameType="1"
    serviceId="2115"
StatusMsgEnd
StatusMsg
    streamId="6"
    name="IBM.N"
    nameType="1"
    serviceId="2115"
StatusMsgEnd
The subscribed item will always be IBM.N.
Could you please share your code?
consumerjava.txt (3.0 KiB)
11.5k 16 7 10
Hello @shawn11
Could you please share us you source code as requested by Jirapongse?
