From the MRN Elektron DAta Models spec:
For a given RIC-MRN_SRC-GUID combination, when a data item requires only a single message, then TOT_SIZE will equal the number of bytes in the FRAGMENT and FRAG_NUM will be 1.
In my code:
If
ntaItem->m_expectedSize > 0 && ntaItem->m_expectedSize == ntaItem->m_fragmentBuffer.length;
then:
decompressedBuf.data = (char*)calloc(ntaItem.m_fragmentBuffer.length * 4, sizeof(char)); decompress(&ntaItem.m_fragmentBuffer, &decompressedBuf);
The decompress function is as follows:
RsslRet NTAConsumer::decompress(const RsslBuffer* _compressed, RsslBuffer* _decompressed) { unsigned int unzipBufferLength; unsigned int additionalUnzipBufferLength; char* unzipBuffer; char* unzipBuffer2; if (_compressed->length == 0) { _decompressed->data = _compressed->data; _decompressed->length = _compressed->length; } unzipBufferLength = _compressed->length * 4; // create a buffer that is about large enough to hold the output additionalUnzipBufferLength = unzipBufferLength; unzipBuffer = (char*)calloc(unzipBufferLength, sizeof(char)); z_stream zStrm; zStrm.zalloc = Z_NULL; zStrm.zfree = Z_NULL; zStrm.next_in = (Bytef*)_compressed->data; zStrm.avail_in = _compressed->length; zStrm.total_out = 0; RsslBool finished = RSSL_FALSE; if (inflateInit2(&zStrm, (16 + MAX_WBITS)) != Z_OK) { free(unzipBuffer); LOG(TAEL_ERROR, "Unable to decompress data: inflateInit2 failed"); return RSSL_RET_FAILURE; } while (!finished) { // increase buffer size if it's too small if (zStrm.total_out >= unzipBufferLength) { unzipBuffer2 = (char*)calloc(unzipBufferLength + additionalUnzipBufferLength, sizeof(char)); memcpy(unzipBuffer2, unzipBuffer, unzipBufferLength); unzipBufferLength += additionalUnzipBufferLength; free(unzipBuffer); unzipBuffer = unzipBuffer2; } zStrm.next_out = (Bytef*)(unzipBuffer + zStrm.total_out); zStrm.avail_out = unzipBufferLength - zStrm.total_out; int error = inflate(&zStrm, Z_SYNC_FLUSH); if (error == Z_STREAM_END) { finished = RSSL_TRUE; } else if (error != Z_OK) { break; } } if (inflateEnd(&zStrm) != Z_OK) { free(unzipBuffer); return RSSL_RET_FAILURE; } if (_decompressed->length < zStrm.total_out) { _decompressed->data = (char*)realloc(_decompressed->data, zStrm.total_out * sizeof(char)); _decompressed->length = zStrm.total_out; } strncpy(_decompressed->data, unzipBuffer, zStrm.total_out); free(unzipBuffer); return RSSL_RET_SUCCESS; }
When I print the decompressed data I see trailing garbage characters at times. Please can you help resolve the parsing issue?
For example:
{"analytics":{"analyticsScores":[{"assetClass":"CMPNY","assetCodes":["P:4295906442","R:FITB.O","R:FITB.OQ"],"assetId":"4295906442","assetName":"Fifth Third Bancorp","brokerAction":"UNDEFINED","firstMentionSentence":1,"linkedIds":[{"idPosition":0,"linkedId":"tr:Bw53zx21a_1803192Rxc8Npn0GKDazbXeuL3x6tqy0DwdBbyXJoqBY"},{"idPosition":1,"linkedId":"tr:Bw33SsfHa_18031521zCrUtMvVPYx7mDyov4S+np/9B9vNmh89QWsW"}],"noveltyCounts":[{"itemCount":1,"window":"12H"},{"itemCount":1,"window":"24H"},{"itemCount":1,"window":"3D"},{"itemCount":2,"window":"5D"},{"itemCount":2,"window":"7D"}],"priceTargetIndicator":"UNDEFINED","relevance":1.00000,"sentimentClass":1,"sentimentNegative":0.0896546,"sentimentNeutral":0.342679,"sentimentPositive":0.567667,"sentimentWordCount":629,"volumeCounts":[{"itemCount":2,"window":"12H"},{"itemCount":2,"window":"24H"},{"itemCount":2,"window":"3D"},{"itemCount":12,"window":"5D"},{"itemCount":17,"window":"7D"}]}],"newsItem":{"bodySize":4377,"companyCount":1,"exchangeAction":"UNDEFINED","headlineTag":"","marketCommentary":false,"sentenceCount":35,"wordCount":634},"systemVersion":"TS:40060091"},"id":"tr:Bw6t7HLsa_180319229lzk5RNAfh1wEpeo0Fk66vPj8mB0uqLP75Qf","newsItem":{"dataType":"News","feedFamilyCode":"tr","headline":"Fifth Third Bank Introduces Card-free ATMs","language":"en","metadata":{"altId":"nBw6t7HLsa","audiences":["NP:BSW","NP:CNR"],"feedTimestamp":"2018-03-19T16:25:00.223Z","firstCreated":"2018-03-19T16:25:00.174Z","isArchive":false,"takeSequence":1},"provider":"NS:BSW","sourceId":"Bw6t7HLsa_180319229lzk5RNAfh1wEpeo0Fk66vPj8mB0uqLP75Qf","sourceTimestamp":"2018-03-19T16:25:00.174Z","subjects":["B:125","B:126","B:127","B:128","B:161","B:1616","B:162","B:168","B:169","B:172","B:174","B:195","B:234","B:239","B:242","B:261","B:262","B:278","B:279","B:282","B:34","B:43","B:49","G:4","G:6J","G:9","G:9F","M:1P2","M:1QD","M:1WN","M:3","M:32","M:E7","M:H1","M:I4","M:S","M:Z","R:FITB.O","N2:AMERS","N2:BISV","N2:BISV08","N2:BNKCOM","N2:BNKS","N2:BSUP","N2:BSVC","N2:CMPELC","N2:CMPNY","N2:CMSS","N2:CMSS08","N2:COMP08","N2:ENT","N2:FINS","N2:FINS08","N2:FLM","N2:GEN","N2:HARW","N2:INDS","N2:INDS08","N2:ISER","N2:ISER08","N2:LEN","N2:NAMER","N2:NEWR","N2:SOCI","N2:SOFW","N2:SRVCS","N2:SWIT","N2:TECH","N2:TECH08","N2:TEEQ","N2:TEEQ08","N2:TMT","N2:US","N2:USAGA","N2:WWW","P:4295906442"],"urgency":3}}q<BE>^A
