EMA NIP publisher / SCF consumer
Hi. If I have a publisher written using the EMA NIP api will another team who are still using the legacy SCF api be able to connect and consume from it. I'm planning to update their code to an EMA consumer but would like to use their existing code for testing.
thanks David
Hi @david.gardiner, The SFC API applications use legacy Marketfeed data format, and are unable to consume the OMM data which EMA NIP publisher publishes over RSSL protocol. So your SFC app will not be able to connect to EMA NIP publisher.
The TREP infrastructure components (ADS) can be configured to downconvert data from OMM -> Marketfeed to cater to these clients. This auto conversion will work for OMM MarketPrice domain messages only.
thanks @Gurpreet.
