Is there a plan to support programmatic configuration in Java EMA? According to API compatibility matrix/capability, the feature is supported in C++ , but not Java EMA. Thanks
EMA Java v.1.2.1 now supports the programmatic configuration.
You can download the package from Elektron SDK - Java Downloads tab.
The software package also provides an example application, example421__MarketPrice__ProgrammaticConfig, which demonstrates how to create and use the programmatic configuration feature of EMA.
You can refer to this article.
On EMA Java, you can programmatically change some key parameters.
For example, host or username.
Hi @RG1
You can submit this question to Development directly by submit a new issue in Elektron SDK GitHub page.
