How do i use the /caseReferences api to get the CaseSystemId from CaseId? How to use the "Query" parameter type in Get request?
world-checkworld-check-onescreeningcase
Hi @aurag.patil,
when you create a new case using the /cases function you can optionally supply a case-id value, if you do not do so, one is generated, and in both situations this value is returned in the case-id value of the response from the cases call.
This case-id value can then be used with the /casereferences call to get the case-system-id which is required to fetch/update the actual details of a case.
regards,
Hi @Joseph.McClean
Yes, I am aware of that, what I want to know is how do I pass the case id in /casereferences API. As "Case Id" is Query parameter type. So not sure is it path of Get request or any other way??
Hi @Anurag.Patil,
for /casereferences the case-id should be added to the path of the get request e.g. in C# it would be
https://rms-world-check-one-api-pilot.thomsonreuters.com/v1/caseReferences?caseId=case-id-value
where the case-id-value is the value returned in the cases response
testcasereferencemain.zip Hi @Joseph.McClean
Thanks for your help. But now I am getting an Unauthorized exception in response. Actually, I am using the test credentials by TR team (Shilpi Saha).
Below is the code I am trying, PFA the simple main class where I am using it. I just want to test the API integration, if it works then I can get my own API credentials.
URL : https://rms-world-check-one-api-pilot.thomsonreuters.com/v1/caseReferences?caseId=12345
Can you help me to get this code working??
