Hi Team,
I'm getting concurrent modification exception issue when trying to close the ommcomsumer. Can you please take a look at the issue? Is it a known issue in the api?
Nov 20, 2017 5:11:54 PM com.thomsonreuters.ema.access.ChannelDictionary processCallback WARNING: loggerMsg ClientName: ChannelDictionary Severity: Warning Text: RDMDictionary stream was closed with status message streamId 3 Reason State: Closed/Suspect/None - text: "Login stream was closed." loggerMsgEnd Nov 20, 2017 5:11:54 PM com.thomsonreuters.ema.access.ChannelDictionary processCallback
WARNING: loggerMsg ClientName: ChannelDictionary Severity: Warning Text: RDMDictionary stream was closed with status message streamId 4 Reason State: Closed/Suspect/None - text: "Login stream was closed." loggerMsgEnd
Exception in thread "main" java.util.ConcurrentModificationException at java.util.HashMap$HashIterator.remove(HashMap.java:1451) at com.thomsonreuters.ema.access.OmmBaseImpl.rsslReactorDispatchLoop(Unknown Source) at com.thomsonreuters.ema.access.OmmBaseImpl.uninitialize(Unknown Source)
