how to View old and new ric with change date in HistoricalReference on demand raw extract
want to get this kind of data
sdate edate old new current
2014.08.24 2099.01.01 8321.HK 0048.HK 0048.HK
2015.06.15 2099.01.01 DEA0V6ZA.D 00E1.D 00E1.D
2015.06.15 2099.01.01 DEA0V6ZA.SG 00E1.SG 00E1.SG
2015.06.15 2099.01.01 DEA0V6Y7.D 00E2.D 00E2.D
2015.06.15 2099.01.01 DEA0V6Y7.SG 00E2.SG 00E2.SG
2015.06.15 2099.01.01 DEA0V6Y8.D 00E3.D 00E3.D
2015.06.15 2099.01.01 DEA0V6Y8.SG 00E3.SG 00E3.SG
2015.06.15 2099.01.01 DEA0V6YU.D 00E4.D 00E4.D
2015.06.15 2099.01.01 DEA0V6YU.SG 00E4.SG 00E4.SG
2015.06.15 2099.01.01 DEA0V6ZC.D 00E5.D 00E5.D
2015.06.15 2099.01.01 DEA0V6ZC.SG 00E5.SG 00E5.SG
2015.06.15 2099.01.01 DEA0V6ZR.D 00E6.D 00E6.D
2015.06.15 2099.01.01 DEA0V6ZR.SG 00E6.SG 00E6.SG
2015.06.15 2099.01.01 DEA0V6ZF.D 00E7.D 00E7.D
2015.06.15 2099.01.01 DEA0V6ZF.SG 00E7.SG 00E7.SG
2015.06.15 2099.01.01 DEA0V6ZU.D 00E8.D 00E8.D
2015.06.15 2099.01.01 DEA0V6ZU.SG 00E8.SG 00E8.SG
2015.06.15 2099.01.01 DEA0V6YS.D 00E9.D 00E9.D
2015.06.15 2099.01.01 DEA0V6YS.SG 00E9.SG 00E9.SG
how do I get it ?
tick-history-rest-apihistorical
23k 22 9 14
It can get a bit complex to sort out by first appearance of the RIC in the historical reference result. So alternatively, like to suggest taking a look at
{ {protocol}}{ {host}}{ {api}}Search/HistoricalSearch
  "Request": {
    "Identifier": "KYG211351195",
    "IdentifierType": "Isin",
    "Range": {
      "Start": "1995-01-01T00:00:00.000Z",
      "End": "2017-01-01T00:00:00.000Z"
we get back multiple entries such as
            "Identifier": "0048.HK",
            "IdentifierType": "Ric",
            "Source": "",
            "Key": "VjF8MHgzMDAwMDAwMDAwMDAwMDAwfDB4MzAwMDAwMDAwMDAwMDAwMHx8fHx8fHwwMDQ4LkhLfA",
            "Description": "Historical Instrument",
            "InstrumentType": "Unknown",
            "Status": "Valid",
            "DomainCode": "6",
            "FirstDate": "1996-01-01T00:00:00.000Z",
            "LastDate": "2017-11-06T00:00:00.000Z",
            "History": []
To make sense, we concentrate only on DomainCode=6, MarketPrice.
FirstDate and LastDate are the dates when the sinstrument was first valid and last valid,
with the exception of the instrument which is still valid, then LastDate will be the request date.
Does this request work better for your use case?
Thanks it works but How to send single request for multiple ISIN's or Do I have to send Individual request for each ISIN ? Like in on Demand Extraction there is identifier List Dict in JSON format, something like that..
@ykr314,
Yes. With this request type, you can only submit one identifier at a time.
23k 22 9 14
I think a good way is HistoricalReferenceExtractionRequest.
Please refer to REST API Tutorial 10 - Historical Reference
Similar to this:
    "ExtractionRequest": {
        "@odata.type": "#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.HistoricalReferenceExtractionRequest",
        "ContentFieldNames": [
           "RIC", "CUSIP", "ISIN", "SEDOL", "Issuer OrgID", "Exchange Code", "Currency Code", "Change Date"
        "IdentifierList": {
            "InstrumentIdentifiers": [
                    "Identifier": "DEA0V6ZA.D",
                    "Identifier": "00E1.SG",
                    "Identifier": "00E2.D",
            "ValidationOptions": {"AllowHistoricalInstruments": true},
            "UseUserPreferencesForValidationOptions": false
        "Condition": {
            "StartDate": "1996-05-01T00:00:00.000Z",
            "EndDate": "2017-05-31T23:59:59.000Z"
This request gives me data in this form
RIC Change Date
"CKF.AX" "2017/01/01"
"BVIC.L" "2017/01/01"
"BVIC.L" "2017/03/22"
"BVIC.L" "2017/03/28"
"BVIC.L" "2017/03/30"
"BVIC.L" "2017/04/11"
"BVIC.L" "2017/07/11"
"BVIC.L" "2017/07/13"
"BVIC.L" "2017/07/15"
"BAER.S" "2017/01/01"
"BAER.S" "2017/07/27"
"BAER.S" "2017/10/18"
"600059.SS" "2017/01/01"
"600059.SS" "2017/07/31"
but along with change date, I also want to know what was this RIC before change date? What it has changed to ? and What is current RIC ?
23k 22 9 14
Depending on the use case. Let's take an example of RIC
0048.HK -> 0048.HK^A12-> 8321.HK
Once we have run the previous request, we know the common Isin = KYG211351195
We can issue
        "IdentifierList": {
        "Condition": {
         "StartDate": "1990-05-01T00:00:00.000Z",
The received data will contain multiple change dates with RICs across this ISIN, with increasing change date.
The first set of changes carries the original RIC 0048.HK. The first occurrence of
0048.HK^A12 is when it was first valid. Then we have multiple changes of
0048.HK^A12 and the last set of changes contains RIC 8321.HK, the first one being when it was first valid.
Do you see how Historical Reference can be used to derive the RICs?
This kind of works as this gives me this data,
how do I know on which date Ric actually changed ?
@ykr1314,
This should be the first raw with the changed RIC, in the column "Change Date"
Can't understand, can you elaborate ??
