The ERROR static value is missing from the DataTypes class.
Because of that the following code snippet extracted from the example200__MarketPrice__Streaming example doesn't compile anymore.
switch (fieldEntry.loadType()) { case DataTypes.REAL : System.out.println(fieldEntry.real().asDouble()); break; . . . case DataTypes.ERROR : System.out.println("(" + fieldEntry.error().errorCodeAsString() + ")"); break; default : System.out.println(); break; }
Is DataTypes.ERROR still a relevant data type?
What is the recommended way to deal with field entries that contain errors?
