DSS: Tick History Market Depth Report with Query Types = Schedule relative query - Error in API
i use .NET DSS REST API.
under DSS i have set up the following 'Tick History Market Depth Report':
When i choose the schedule Relative Query, there is a parse error when i retrieve the report via the API.
ExtractionsContext.ReportTemplateOperations.GetByName("TEST")
the exception is:
It seem the enum ReportDateRangeType does not have the 'Relative' value
Can you check this?
Pierre
Hello @PBI,
Just to double-check, you are using C# API to retrieve and your version is the latest?
I just tried to reproduce, created a relative query via GUI and GetByName-ed it via API:
ExtractionsContext.ReportTemplateOperations.GetByName("myTandSTemplateName"
Did not reproduce this issue, received HTTP Response:
 "ApplyCorrectionsAndCancellations": false,
        "ReportDateRangeType": "Relative",
        "RelativeStartDaysAgo": 0,
        "RelativeEndDaysAgo": 0,
        "RelativeStartTime": "00:00:00.000",
        "RelativeEndTime": "23:59:59.000",
@PBI
The latest ReportDateRangeType defined in https://hosted.datascopeapi.reuters.com/RestApi/v1/Extractions/$metadata has Relative enum.
<EnumType Name="ReportDateRangeType">
  <Member Name="NoRange" Value="0"/>
  <Member Name="Init" Value="1"/>
  <Member Name="Range" Value="2"/>
  <Member Name="Delta" Value="3"/>
  <Member Name="Last" Value="4"/>
  <Member Name="Relative" Value="5"/>
</EnumType>
However, ReportDateRangeType defined in .NET SDK 11.1.527.0 doesn't have this Relative enum.
public enum ReportDateRangeType
        NoRange = 0,
        Init = 1,
        Range = 2,
        Delta = 3,
        Last = 4,
Please directly submit the query to TRTH V2 support team via Contact Us. Please select product: Thomson Reuters Tick History v2.
@PBI
You can download the latest version 11.1.558 from REST API Help page.
It contains Relative enum.
        NoRange = 0,
        Init = 1,
        Range = 2,
        Delta = 3,
        Last = 4,
        Relative = 5,
The SDK version in the community has just been updated. It is available under the downloads tab.
Thanks @jirapongse.phuriphanvichai, @Christiaan Meihsl
No error with the version 11.1.558.0
Hello @zoya.farberov
i use this version: 11.1.527.0 (is the last version?)
My report type is a TRTH Market Depth report:
Pierre
