Can you help me analyze this problem?
2017-09-29 02:38:09.977 [Thread-6] ERROR com.thomsonreuters.ema.access.OmmConsumerImpl - loggerMsg ClientName: LoginCallbackClient Severity: Error Text: RDMLogin stream was closed with status message username rmds usernameType 1 State: Closed/Suspect/Login rejected, exceeded maximum number of mounts per user - text: "Exceeded maximum number of mounts per user." loggerMsgEnd
And I don't use user "test" to login, why do I receive this message after the above one?
2017-09-29 02:38:54.651 [Thread-8] ERROR com.thomsonreuters.ema.access.OmmConsumerImpl - loggerMsg ClientName: LoginCallbackClient Severity: Error Text: RDMLogin stream was closed with status message username test usernameType 1 State: Closed/Suspect/None - text: "Error! User test is not registered" loggerMsgEnd
