How can I use proxy settings on ExtractionsContext C# examples
I'm trying to get field list for TickHistoryTimeAndSales report using below proxy settings. It does not seem to be working. Could you please tell me how to use the proxy setting in the QickStart C# examples?
var ExtractionsContext = new ExtractionsContext(new Uri("https://hosted.datascopeapi.reuters.com/RestApi/v1/"), "UserName", "Password");
var proxy = new WebProxy("http://MyProxy:Port", true);
var credentials = new NetworkCredential("UserName", "Password"); ExtractionsContext.Options.UseProxy = true;
ExtractionsContext.Options.Proxy = proxy;
ExtractionsContext.Options.Proxy.Credentials = credentials;
var availableFields = ExtractionsContext.GetValidContentFieldTypes(ReportTemplateTypes.TickHistoryTimeAndSales);
tick-history-rest-apic#proxy
It is okay if I only set proxy without NetworkCredential.
However, if I set NetworkCredential, it will not work. I will investigate this issue and keep you posted.
DSS .NET SDK version 11.3 is available. From my test, it supports proxy with Network Credential. You can download it from here.
The code is:
ExtractionsContext extractionsContext =
                 new ExtractionsContext(dssUri, dssUserName, dssUserPassword);
WebProxy proxy = new WebProxy("http://proxy:port/", true);
proxy.Credentials = new NetworkCredential("proxyuser", "proxypassword");
extractionsContext.Options.Proxy = proxy;
extractionsContext.Options.UseProxy = true;
