one RIC but many files (change date, expiration date)
RIC: ESM0 (RawLegacyMarketDepth)
Problem:
I find RIC: ESM0, as shown in the pictures, under RIC: ESM0 there are many files with different "Change Date" and "Expiration Date" (06/18/2020 and 06/19/2020)
Which of these RICs is correct?
Problem, downloading everything, all RIC: ESM0 with different "Change Date" and "Expiration Date"
files of 90 gigabytes
Help with the answer, what to change in the code so that only one RIC is downloaded with the correct expiration date and where is the earliest update date of the message in history or earliest RIC date.
Please give an example of the code in the answer in C #example code.
code:
using System;
using System.Linq;
using System.Diagnostics;
using System.IO;
using ThomsonReuters.Dss.Api.StandardExtractions;
using ThomsonReuters.Dss.Api;
using ThomsonReuters.Dss.Api.Content;
using ThomsonReuters.Dss.Api.Extractions;
using ThomsonReuters.Dss.Api.Extractions.ExtractionRequests;
using ThomsonReuters.Dss.Api.Extractions.ReportExtractions;
using ThomsonReuters.Dss.Api.Extractions.ReportTemplates;
using ThomsonReuters.Dss.Api.Extractions.Schedules;
using ThomsonReuters.Dss.Api.Extractions.SubjectLists;
using ThomsonReuters.Dss.Api.Search;
using ThomsonReuters.Dss.Core.RestApi;
using System.Text;
using ICSharpCode.SharpZipLib.GZip;
namespace RefinitivHistoryTesting
    class Program
        static void Main(string[] args)
            //Connect and authenticate to the DSS server:
            Uri dssUri = new Uri("https://hosted.datascopeapi.reuters.com/RestApi/v1/");
            string dssUserName = "*****";
            string dssUserPassword = "*****";
            var out_dir = @".\Storage\";
            var SearchContext = new SearchContext(dssUri, dssUserName, dssUserPassword);
            var ExtractionsContext = new ExtractionsContext(dssUri, dssUserName, dssUserPassword);
            ExtractionsContext.Options.AutomaticDecompression = false;
            try
                ExtractionsContext.DefaultRequestHeaders.Add("x-direct-download", "true");
            catch (Exception)
            var availableMbPFields = ExtractionsContext.GetValidContentFieldTypes(ReportTemplateTypes.TickHistoryRaw);
            var availableTnSFields = ExtractionsContext.GetValidContentFieldTypes(ReportTemplateTypes.TickHistoryTimeAndSales);
            var dateRange = DateTimeRange.Create(
                new DateTimeOffset(2008, 01, 01, 0, 0, 0, TimeSpan.Zero),
                new DateTimeOffset(2020, 12, 22, 0, 0, 0, TimeSpan.Zero));
            var request = new HistoricalChainResolutionRequest
                ChainRics = new[] { "0#ESM0" },//{ "0#ESH1"},//{ "0#ECSSH1" },//{ "0#1URO:" },
                Range = dateRange
            var chain_results = SearchContext.HistoricalChainResolution(request);
            foreach (var chain in chain_results)
                Console.WriteLine("Chain Identifier: {0} {1}, Constituents: {2}", chain.IdentifierType, chain.Identifier, chain.Constituents.Count());
                foreach (var constituent in chain.Constituents)
                    var searchResults = SearchContext.HistoricalSearch(
                        HistoricalSearchRequest.Create(
                            constituent.Identifier, constituent.IdentifierType, dateRange, HistoricalResultsBy.Ric, null));
                    //foreach (var result in from pos in searchResults where pos.DomainCode == "8" select pos)
                    //foreach (var result in searchResults)
                    var result = searchResults.FirstOrDefault(pos => pos.Identifier.Contains("ESM0"));//("ESH1m"));//("ECSSH1"));
                    if (result != null)
                        var extractionDatesResult = ExtractionsContext.Extract(
                            new HistoricalReferenceExtractionRequest
                                ContentFieldNames = new DssCollection<string>()
                                    "RIC", "Start date", "Change Date", "Expiration Date"
                                Condition = new HistoricalReferenceCondition
                                    StartDate = result.FirstDate,
                                    EndDate = result.LastDate
                                IdentifierList = new InstrumentIdentifierList
                                    InstrumentIdentifiers = new[]
                                        InstrumentIdentifier.Create(result.IdentifierType, result.Identifier)
                                    ValidationOptions = new InstrumentValidationOptions
                                        AllowHistoricalInstruments = true
                                    UseUserPreferencesForValidationOptions = false
                       dynamic srcLastDate = null;
                        foreach (var content in extractionDatesResult)
                            foreach (var prop in content.DynamicProperties)
                                Console.WriteLine("{0}\t {1},\r", prop.Key, prop.Value);
                                if (srcLastDate == null && prop.Key == "Expiration Date" && prop.Value != null) srcLastDate = prop.Value;
                        dynamic lastDate = srcLastDate != null ? new DateTimeOffset(srcLastDate) : new DateTimeOffset(DateTime.UtcNow);   //result.LastDate;
                        dynamic startDate = result.FirstDate;//lastDate.AddMonths(-1);//new DateTimeOffset(2020, 12, 22, 0, 0, 0, TimeSpan.Zero); //lastDate.AddMonths(-4);//result.FirstDate;
                        Console.WriteLine("{0},\t {1},\t {2},\t {3},\t {4}", result.Identifier, result.IdentifierType, startDate, lastDate, result.DomainCode);
                        var extractionResult = ExtractionsContext.ExtractRaw(
                               new TickHistoryMarketDepthExtractionRequest
                                    Condition = new TickHistoryMarketDepthCondition
                                        ReportDateRangeType = ReportDateRangeType.Range,
                                        QueryStartDate = startDate, //new DateTimeOffset(2016, 07, 25, 20, 0, 0, TimeSpan.Zero),
                                        QueryEndDate = lastDate, //new DateTimeOffset(2016, 08, 02, 19, 59, 59, TimeSpan.Zero),
                                        ExtractBy = TickHistoryExtractByMode.Ric,
                                        MessageTimeStampIn = TickHistoryTimeOptions.GmtUtc,
                                        SortBy = TickHistorySort.SingleByRic,
                                        View = TickHistoryMarketDepthViewOptions.LegacyLevel2,
                                        DisplaySourceRIC = true
                        string line;
                        var fileName = out_dir + "_" + result.Identifier + "_" + startDate.DateTime.ToString("dd.MM.yyyy") + "_" + lastDate.DateTime.ToString("dd.MM.yyyy") + "_RawLegacyMarketDepth.csv";
                        var sw = new StreamWriter(fileName, false);
                        var streamResponse = ExtractionsContext.GetReadStream(extractionResult);
                        using (GZipInputStream gzip = new GZipInputStream(streamResponse.Stream))
                            using (StreamReader reader = new StreamReader(gzip, Encoding.UTF8))
                                while ((line = reader.ReadLine()) != null)
                                    sw.WriteLine(line);
                        sw.Close();
            try
                ExtractionsContext.DefaultRequestHeaders.Remove("x-direct-download");
            catch (Exception)
            Console.WriteLine("Press Enter to exit");
            Console.ReadLine();
tick-history-rest-apic#Download
23k 22 9 14
Hello @s61670,
These are, from my understanding, the results of Historical Reference requests. They are search results, rather then files.
Historical Reference request aims to provide the complete set of information for the instrument, in history, and instruments, over the years, sometimes undergo changes, this is the history of any changes that have taken place.
You can use this request, to identify the Expiration Date, for an instrument.
You do not need to request the biggest file, in my understanding. From the other question, you were looking to request the content on the Expiration Date, this request provides you with the Expiration date to use
If you require to learn more about every specific change that the instrument has underwent over the history, you will need to request additional fields, to pinpoint these changes.
From the API usage perspective, you can learn more about Historical Reqference request, and how to obtain the complete list of the available fields, so that you can select the fields that you require from this tutorial .
As a customer, if you need help identifying the required content and explaining it, the best way is to refer it to Refinitiv Helpdesk Online -> Content , to be connect with the Refinitiv content expert for your required content set. The members of dev forum and moderators are developers, and are not experts in all diverse kinds of content that are provided by Refinitiv.
very different size between files. The first file was downloaded 90 gigabytes, the second 285 gigabytes.
