Why VBD files not getting downloaded as gip file with StandardExtractions/UserPackageDeliveries?
Thanks. I see files are duplicated for all exchanges for 08/08.
I could download for 08/09..
Please look into this.
@satish.shioshankar.gaidhane
I have contacted content team to investigate this issue. Will keep you posted.
Sorry for the delay. Content team has informed that the duplicates are due to missing content issue in TRTH v2 Venue By Day files.
On backfilling the missing date, we had released a new set of files without deleting the old files (with missing content) which lead to confusion of duplicates.
we getting below error:
{"error":{"message":"The requested file was not found in AWS."}}
Command ran :
curl -H "Prefer:respond-async" -H "Content-Type:application/json" -H "Authorization: Token token" -H "Accept-Charset: UTF-8" "https://hosted.datascopeapi.reuters.com/RestApi/v1/StandardExtractions/UserPackageDeliveries('0xvfdvfdfd')/\$value"
pakageDeliverId above is modified for security. also token is deleted
O/p:
Could you provide the file name of VBD you are trying to download?
OPQ-2017-08-08-NORMALIZEDMP-Data-1-of-5.csv.gz
this as well
ASQ-2017-08-08-NORMALIZEDMP-Data-1-of-1.csv.gz
11.3k 25 8 13
Which programming language or command you use for downloading the VBD file? Could you provide more information? The VBD files normally is downloaded as data stream in gzip format.
If you use cURL, you need to add the -o <filename.gz> option to save the gzip data to file.
You can see the example in this question for cURL and this question for Java.
I used -o as well..
and also without -o, I don't see o/p on screen.. it showing error..
O/p :
11.3k 25 8 13
I am able to replicate the error by downloading the file: OPQ-2017-08-08-NORMALIZEDMP-Data-1-of-5.csv.gz via API. The file also cannot be downloaded from Web GUI. It returns 404 - Not Found once I try to preview it. I will escalate this issue.
There is another file named "OPQ-2017-08-08-NORMALIZEDMP-Data-1-of-4.csv.gz" which can be downloaded. Could you please veriy the file?
Could you please try to download below file using
StandardExtractions/UserPackageDeliveries('ID)/\$value"
I am not able to download.
Also I don't see duplicate files for this exchange and for 08/08.
Yes, this file also returns Not Found.
