Unsupported environment in EMA
While trying to compile one of the examples from EMA api (100_Series_Examples/100__MarketPrice__Streaming), it threw an error that the environment is unsupported. Is RED HAT necessary for running EMA or will ubuntu suffice?
elektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-apilinuxubunturedhat
11.5k 16 7 10
Hello @achyut
The EMA APIs (both C++ and Java editions) are supported and have been tested with the following Linux OS only
  • Oracle Linux 6.0 - 64 bit
  • Oracle Linux 7.0 - 64 bit
  • Red Hat Enterprise Linux 6.X - 64 bit
The other Linux distributions are not guarantee to work and support for the EMA APIs.
i don't need support - I just want it to build it and use the API. Apparently, you can't even do that! Is that correct?
