StandardExtractions/UserPackageDeliveryGetUserPackageDeliveriesByDateRange
This endpoint only gives data for last day mentioned.
ex.
"https://hosted.datascopeapi.reuters.com/RestApi/v1/StandardExtractions/UserPackageDeliveryGetUserPackageDeliveriesByDateRange(SubscriptionId='0x0d24a00cb4',FromDate=2017-07-30T00:59:00.000Z,ToDate=2017-08-02T23:59:00.000Z)"
Here it is giving files for 20170802 only.. no files from 20170730 to 20170801.
Could you please advise.
11.3k 25 8 13
@satish.shioshankar.gaidhane
The UserPackageDeliveryGetUserPackageDeliveriesByDateRange method uses the Server-Driven Paging mechanism to deliver data. It will return the first page of results (typically 250 rows) on the initial request. The initial server response will include a nextlink(URI) that, when called, will return the next 250 rows for that result set as well as another nextlink.
It is possible that your endpoint returns results more than 250 rows, so you need to request the nextlink URI at the end of the response to retrieve next page.
Please note that there currently is an issue on returned URI, where sometimes the URI is returned in "http" instead of "https". You need to manually change it to "https", before sending the request.
Below is the sample of response.
            "PackageDeliveryId": "0x05d194f020bb3026",
            "UserPackageId": "0x04f21a8d19759cb1",
            "SubscriptionId": "0x0400dc1d24a00cb4",
            "Name": "CME-2017-08-02-REF-Data-CUSIP-SEDOL-GICS-1-of-1.csv.gz",
            "ReleaseDateTime": "2017-08-03T03:00:00.000Z",
            "FileSizeBytes": 20866,
            "Frequency": "Daily",
            "ContentMd5": "dc68d0d97c9a4924ba12dddcc29c0631"
            "PackageDeliveryId": "0x05d194ef1d5b3026",
            "UserPackageId": "0x04f21a8d2be59cb1",
            "Name": "SGO-2017-08-02-REF-Report-1-of-1.csv.gz",
            "FileSizeBytes": 47595,
            "ContentMd5": "f914dfe220e19a03404a13495403b2aa"
    "@odata.nextlink": "https://hosted.datascopeapi.reuters.com/RestApi/v1/StandardExtractions/UserPackageDeliveryGetUserPackageDeliveriesByDateRange(SubscriptionId='0x0400dc1d24a00cb4',FromDate=2017-07-30T00:59:00.000Z,ToDate=2017-08-02T23:59:00.000Z)?$skiptoken='MjAxNy0wOC0wMlQyMzoxNjowMi42NDYwMDAw'"
