Is there an option to retrieve the host name and port connection for the instance of OmmConsumer or Omm ConsumerConfig. The connection details of host and port are stored in EmaConfig.xml
This is required to log the connection details.
Hello @sagar.s
If the current EMA Java cannot serve your requirements, you can submit your requirements as an Issue of EMA Java product(like raise an enhancement request) at
https://github.com/thomsonreuters/Elektron-SDK/issues then click "New issue" button. This way allows you to contact with the development team directly.
Hello @sagar.s
I have not found any method of OmmConsumer or OmmConsumerConfig which can retrieve the host name and port connection. However, the latest EMA Java prints the connection details if you enable xml trace log by adding
<XmlTraceToStdout value="1"/> in EmaConfig.xml. For example:
<Consumer> <Name value="Consumer_1"/> ... <XmlTraceToStdout value="1"/> </Consumer>
Then, the connection details e.g. the machine running the application and the server that it connects to are printed.
For example: EMA Java logs a login request message sent from the machine IP/port
10.42.61.169/62139 to the server IP/port 192.168.27.48/14002:
<!-- Outgoing Reactor message --> <!-- java.nio.channels.SocketChannel[connected local=/10.42.61.169:62139 remote=/192.168.27.48:14002] --> <!-- Wed Aug 02 10:52:35 ICT 2017 --> <!-- rwfMajorVer="14" rwfMinorVer="1" --> <REQUEST domainType="LOGIN" streamId="1" containerType="NO_DATA" flags="0x04 (STREAMING)" dataSize="0"> <key flags="0x26 (HAS_NAME|HAS_NAME_TYPE|HAS_ATTRIB)" name="user" nameType="1" attribContainerType="ELEMENT_LIST"> <attrib> <elementList flags="0x08 (HAS_STANDARD_DATA)"> <elementEntry name="ApplicationId" dataType="ASCII_STRING" data="256"/> <elementEntry name="ApplicationName" dataType="ASCII_STRING" data="ema"/> <elementEntry name="Position" dataType="ASCII_STRING" data="10.42.61.169/U8007607-TPL-A"/> <elementEntry name="Role" dataType="UINT" data="0"/> </elementList> </attrib> </key> <dataBody> </dataBody> </REQUEST>
Thanks for the reply. If I use <XmlTraceToStdout value="1"/>, it fills up the heap space if I query RICs. I do not think it would be the right fit.
