Hello everybody,
I saw here :
that the method GetAllInstruments, of object InstrumentList, should allow to get the list of instruments associated with an InstrumentList.
So, I typed this code :
instrumentList = new InstrumentList { Name = strInstrumentListName }; List<InstrumentIdentifier> lii = instrumentList.GetAllInstruments();
But, I then obtained this exception at compile time :
Error CS1061 'InstrumentList' does not contain a definition for 'GetAllInstruments' and no extension method 'GetAllInstruments' accepting a first argument of type 'InstrumentList' could be found (are you missing a using directive or an assembly reference?)
Where is the problem ? Does the documentation refer to another context ? Am I supposed to declare another reference ?
Or is it better to do it like this ?
var fromInstrumentList = extractionsContext.InstrumentListOperations.GetAllInstruments(listId);
