instrument list / template / schedule | GUI vs API
To schedule an extraction, we have to
- create an instrument list to define the scope
- create template to define the result format.
same action on both GUI and API.
I would like to know if it's possible to crate a template in GUI, and then use it in API mode?
Thanks in advance for your answer.
David LY. ( java user )
tick-history-rest-apiricstemplategui
Hi @davly182,
Yes, you can absolutely do that with the TRTH REST API. I recommend the REST API Tutorial 11: GUI control calls: immediate extract tutorial that explains everything you need to know in that domain (and even more). If you develop in java I also recommend the Programming without SDK Tutorial that explains how to use the API in java.
@davly182
To add a few more details:
  • You can create / update / delete instrument lists using the GUI or the API. That is also valid for report templates.
  • Items you created using the GUI (or the API) can be re-used from the API (or the GUI).
  • The java sample DSS2ImmediateScheduleIntradayBarsTRTHClient (available in the downloads) contains methods that illustrate the use of the API calls to retrieve an instrument list (or report template) by name.
