TRTH token
I have some questions about the token generated to use TRTH APIs.
Is there a limit of concurrent live tokens? We have around 30 processes that create their own token. Would it be better to share one token ?
We also have a test environment where we run unit tests. With trth the tests generate a temporary token. Is it going to invalidate past tokens?
thanks
Alvise
tick-history-rest-apitoken
13.7k 26 8 12
@alvise.susmel,
  • You can create as many tokens as you want, as often as you want, there is no limit.
  • You can create a mechanism to share a token among your 30 processes, but it is not obligatory, they can each use their own token.
  • A token does not invalidate a prior token, each token is independent, and remains valid 24 hours.
For additional details, see the Tick History 11.1 REST API user guide, chapter 4.
Thanks Christianan. I've just created a system to share the token using redis. In this way it's a bit cleaner.
Thank you very much for your prompt reply
