Is it possible to retrieve the information regarding RICs from Eikon WORLD/CHANGE, for example DE/CHANGE2 from Eikon COM APIs?
Many thanks in advance,
Best regards
Richard Sponda
Best regards
Richard Sponda
Hi Richard,
You can retrieve text from these pages using AdfinX Real Time library just like you retrieve data from any other RIC. See Tutorial 2 on COM APIs for use in custom applications
https://developers.refinitiv.com/en/api-catalog/eikon/com-apis-for-use-in-custom-applications/tutorials#tutorial-2-access-real-time-data
In Step 3 instead of AdxRtList.RegisterItems("GBP=", "BID") use for example AdxRtList.RegisterItems({"DE/CHAGES2","DE/CHAGES3"}, {"ROW80_2","ROW80_3","ROW80_4",...,"ROW80_25"})
Since this data is not updating frequently instead of AdxRtList.StartUpdates(RT_RunMode.RT_MODE_ONUPDATE) you should use AdxRtList.StartUpdates(RT_RunMode.RT_MODE_IMAGE);
And finally instead of callback for OnUpdate event you should create callback for OnImage event.
To tell you if there's a better way I need to know the end goal, i.e. how you intend to use this information or what problem you intend to solve with it. Otherwise I can for example suggest that you subscribe to Content Notifications via e-mail from Thomson Reuters "My Account" portal (http://my.thomsonreuters.com/pages?name=notifications). Is this a better way for you to receive this information? I couldn't possibly tell, could I?
Hi Richard,
You can retrieve these pages using AdfinX Real Time COM library. But the data on these pages is basically unstructured text, which you would have to parse and somehow make sense of. Perhaps if you share your end goal, I may suggest an alternative?
Hi Alex,
I would like to retrieve information about planned RIC changes for a list of RICs.
How is this possible with the AdfinX library? Is there a better way to get this information?
Best regards
Richard Sponda
