Hello @nazar.viliura
You can cancel a job by issuing a delete to the monitor URL. For example:
DELETE https://hosted.datascopeapi.thomsonreuters.com/restapi/v1/Extractions/ExtractRawResult(ExtractionId='0x05432da4dd2e2e3f') Authorization: Token >your_auth_token_goes_here<
For more details, please refer to Key Mechanisms in DSS Web GUI,
thanks, Pimchaya. Just tried this option and got
'ThomsonReuters.Dss.Api.ValidationException: 'This extraction request does not support cancellation. Details: report template: TimeseriesPricing' exception. Then looked at the link you've provided and found this: "Only Tick History jobs support cancellation."
So, how to handle other request types? Do you know if there is such a possibility to cancel pending jobs from the UI? (https://hosted.datascope.reuters.com/DataScope/Home)
thanks in advance,
Nazar
I do not see any job shown in DSS Web UI as shown below:
Only instrument lists, report templates, schedules etc. can be deleted/canceled. Hence, jobs which is not Tick History cannot be canceled as mentioned in Key Mechanisms
there are two options:
(1) select 'Extracted Files' and you'll see 'Pending Extractions' there
(2) you can select 'Executing Jobs' under your user preferences dropdown
