i'm using axis 1.4 to get data from soap trth api 5.8.
Caught several exceptions yesterday ( May 3, 2017) from 22:00 to 22:30 UTC. All those exceptions look the same and have "Connection timed out" in their description (pasted one below as an example). There were no such issues before 22:00 and after 22:30 UTC.
Is it possible that there was some maintenance going on at the time (22:00 - 22:30 UTC, May 3, 2017)?
Exception example:
Exception in thread "main" AxisFault
faultCode: {
http://schemas.xmlsoap.org/soap/envelope/}Server.userException
faultSubcode:
faultString: java.net.ConnectException: Connection timed out (Connection timed out)
faultActor:
faultNode:
faultDetail:
http://xml.apache.org/axis/}stackTrace:java.net.ConnectException: Connection timed out (Connection timed out)
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:327)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:193)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:180)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:384)
at java.net.Socket.connect(Socket.java:543)
at sun.security.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:614)
at sun.security.ssl.SSLSocketImpl.<init>(SSLSocketImpl.java:411)
at sun.security.ssl.SSLSocketFactoryImpl.createSocket(SSLSocketFactoryImpl.java:88)
at org.apache.axis.components.net.JSSESocketFactory.create(JSSESocketFactory.java:92)
at org.apache.axis.transport.http.HTTPSender.getSocket(HTTPSender.java:191)
at org.apache.axis.transport.http.HTTPSender.writeToSocket(HTTPSender.java:404)
at org.apache.axis.transport.http.HTTPSender.invoke(HTTPSender.java:138)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.client.AxisClient.invoke(AxisClient.java:165)
at org.apache.axis.client.Call.invokeEngine(Call.java:2784)
at org.apache.axis.client.Call.invoke(Call.java:2767)
at org.apache.axis.client.Call.invoke(Call.java:2443)
at org.apache.axis.client.Call.invoke(Call.java:2366)
at org.apache.axis.client.Call.invoke(Call.java:1812)
