EMAConfig.xml
Can EMAConfig.xml be given as a parameter to
EmaFactory.createOmmConsumerConfig() to load from a specific location instead of looking for the default location of the binary?
The directly answer to your question is NO but there are other ways to load a configuration file from a user specified location and has been discussed before. Please take a look a the thread: https://community.developers.refinitiv.com/questions/8774/view.html
The next ESDK release - ESDK release 1.1.1 - will include a feature that allows application developers to supply an optional path to a configuration file. The path may be a directory, in which case the library will load a file named EmaConfig.xml from that directory, or a filename.
In Java, one will supply this path as an argument to createOmmConsumerConfig; see the example111__MarketPrice__UserSpecifiedFileConfig example for more details. This example is new for this release.
In C++, one will supply this path as an argument to the OmmConsumerConfig constructor; see the 111__MarketPrice__UserSpecifiedFileConfig example for more details. This example is new for this release.
