What is the actual meaning of the integer return updateTypeNum in UpdateMsg Class?
INSTRUMENT_UPDATE_UNSPECIFIED=0
INSTRUMENT_UPDATE_QUOTE=1
INSTRUMENT_UPDATE_TRADE=2
INSTRUMENT_UPDATE_NEWS_ALERT=3
INSTRUMENT_UPDATE_VOLUME_ALERT=4
INSTRUMENT_UPDATE_ORDER_INDICATION=5
INSTRUMENT_UPDATE_CLOSING_RUN=6
INSTRUMENT_UPDATE_CORRECTION=7
INSTRUMENT_UPDATE_MARKET_DIGEST=8
INSTRUMENT_UPDATE_QUOTES_TRADE=9
INSTRUMENT_UPDATE_MULTIPLE=10
INSTRUMENT_UPDATE_VERIFY=11
If I want to capture the traded event, only capture the updateTypeNum =2 with FID = 6, is it correct?
Thanks,
Sam
elektronrefinitiv-realtimetrephistoricaltrade
7.6k 15 6 9
@samuel.yan
Not sure about API you are using. But there are some informations about the meaning of Instrument Update from RFA Reference Manual (.html file) which provided in <RFA Install folder>\Docs\refman\rfa\a00363.html
-INSTRUMENT_UPDATE_UNSPECIFIED=0
Not specified. Data Feed/Provider not specified the type.
-INSTRUMENT_UPDATE_QUOTE=1
The update is Quote
-INSTRUMENT_UPDATE_TRADE=2
The update is Trade
-INSTRUMENT_UPDATE_NEWS_ALERT=3
The update is News Alert
-INSTRUMENT_UPDATE_VOLUME_ALERT=4
The update is Volume Alert
-INSTRUMENT_UPDATE_ORDER_INDICATION=5
The update is Order Indication
-INSTRUMENT_UPDATE_CLOSING_RUN=6
The update is Closing Run
-INSTRUMENT_UPDATE_CORRECTION=7
The update is Correction
-INSTRUMENT_UPDATE_MARKET_DIGEST=8
The update is Official information from the exchange
-INSTRUMENT_UPDATE_QUOTES_TRADE=9
One or more conflated quotes followed by a trade
-INSTRUMENT_UPDATE_MULTIPLE=10
Update with other filtering and conflation applied
-INSTRUMENT_UPDATE_VERIFY=11
Fields may have changed
As far as I understand if you want to capture trade, normally you have to check the updateTypeNum=2 and get trade price from FID 6 but for some exchange it might use other FID to represent trade price. Please check with data support if you can not get it from FID 6.
