Hi Support.
Could you advise if the results being invoked via ThomsonReuters.Dss.RestApi same as the one I am accessing https://hosted.datascope.reuters.com/dataScope.
Example. I am invoking the API ExtractionsContext.ReportTemplateOperations.GetAll() which only returns 11 records but if I will do go to Datascope select website, under
https://hosted.datascope.reuters.com/DataScope/extractions/reports, I have more than 11 records.
and both using the same login and pass.
Best Regards,
Nigil Chua
