HK stock name in Chinese page are not shown properly
Hi Support
our trading plarform HK stock name in Chinese page are not shown properly. I have reported to Thomsan Reuters Customer support and they cant help us and direct us to this developer portal to log this case. We need help from your urgently
elektronrefinitiv-realtimetrep
4.4k 10 6 9
Field 1352 or “DSPLY_NMLL” use RMTES (Reuters Multilingual Text Encoding Standard) string and it can be displayed by converting to UTF-8.
For SFC C++ API, you can use RTRUTF8String class which provide a convenient and efficient way for applications to represent RMTES characters in UTF-8 format.
Here is an example.
void RecordSnapshotClient::processSnapshotSync(RTRSnapshotRecord& record)
  // Access each field from the record using an iterator
  RTRSnapshotRecordIterator iterator = record.iterator();
  for (iterator.start(); !iterator.off(); iterator.forth())
    // Print the name and value of each field
    RTRSnapshotField& field = iterator.field();
    // If field id = 1352 then use RTRUTF8String
    if (field.fid() == 1352)
      RTRUTF8String utf8(field.to_c(), field.count(), RTRUTF8String::RMTES);
      if (!utf8.error())
        printf("%s  %s\n", (const char *)field.name(), utf8.to_c());
    else
      printf("%s  %s\n", (const char *)field.name(), (const char *)field.string());
For SFC Java API, you have to enable RMTES conversion by setting the setRMTESConversion(boolean conversion) of RTRecord or RTField to true.
For EMA C++ API, you can use RmtesBuffer class.
const FieldEntry& fe = fieldList.getEntry();
rmtesBuffer.apply( fe.getRmtes() );
cout << rmtesBuffer.toString() << endl;
@jackychuah
It could be RMTES_STRING. For example, for 2018.HK, the DSPLY_NMLL in RMTES_STRING will look like:
After converting to UTF8, it will display:
Typically, there is an example code in the API developer guide which shows how to convert RMTES to UTF8 or UCS2. The following code is for RFA C++.
RMTESConverter converter;
PartialUpdateReadIterator partialReadIt;
if ( dataBuffer.isPartialUpdates() )
 partialReadIt.start( dataBuffer.getBuffer() );
  while ( !partialReadIt.off() )
  fieldUpdatedBuf = partialReadIt.value();
  offset = partialReadIt.offset();
  converter.setBuffer( fieldUpdatedBuf, offset );
  partialReadIt.forth();
 // For update msg display
 vector = converter.getAsShortString()
else
 converter.setBuffer( dataBuffer.getBuffer() );
 // For refresh msg display
 vector = converter.getAsShortString();
In RFA C++, RMTESConverter is an interface to be used to convert RMTES encoded string into a string of Unicode format.
RMTESConverter::getAsCharString() returns the converted string in UTF8 format and RMTESConverter::getAsShortString() returns the converted string in UCS2 format.
