Search PermID via ISIN or SEDOL
I was wondering if it is possible to search using the Record Matching Open PermID API using ISIN and SEDOL.
Currently it seems like you support only company name, website, ticker, country etc.. but you do not allow matching via ISIN and SEDOL.
Is there a way around it? Or another API that finds PermID via ISIN or SEDOL? Thank you in advance.
Paolo
intelligent-tagging-apipermid-apirest-apiopen-permid-apiisinsedolrecord-matching-api
Yes, you are correct. It doesn't support ISIN or SEDOL. If I define ISIN code in the Standard Identifier field, it will return the following response:
 "outputContentResponse": [
      "ProcessingStatus": "ERROR: Row Num 2, Cause - Composite field [standard identifier] should be in format: '<key1>:<value1>|<key2>:<value2>...'. Relevant keys are [[VEID, CIDGEN, CIK, MXID, RCPID, WorldScopeCompanyID, WorldScopeCompanyPermID, RIC, Ilx, Datastream_Mnemonic, Ticker]]. Original Row: 1,ISIN:US0378331005,,,,,,,",
      "Match Level": "No Match",
      "Original Row Number": "2"
The response states that it doesn't support ISIN or SEDOL.
You may use other APIs, such as TRTH or DSS to convert ISIN or SEDOL to RIC and then use OpenPermID API to find the PermID. Otherwise, you can other fields, such as company name to search.
Thank you. I was hoping there was a more direct way, but I'll try the other APIs. In particular, I found also the EIKON API to be potentially useful. Unfortunately the python bindings are just in early access phase. Do you have a timeline for that?
