I am migrating my consumer applciation from RFA 7 to RFA 8 Java version. I followed the tutorials provided in the RFA 8 package. The problem is previously we used RFA 7 connection type as SSL and now RFA 8 connection type as RSSL. We are able to connect to our server through port: 8101,SSL&RFA 7 but not with port:8101,RSSL&RFA 8. I tried switching port:14002,RSSL&RFA 8. I went through all the guides you provided but i didn't got any luck. Please suggest me the next steps.
I am getting below response in hte logs ..
LoginClient.processEvent: Received Login Response
LoginClient: Received Login Response - MsgType.REFRESH_RESP
MESSAGE
Msg Type: MsgType.REFRESH_RESP
Msg Model Type: LOGIN
Indication Flags: REFRESH_COMPLETE
Hint Flags: HAS_ATTRIB_INFO | HAS_ITEM_GROUP | HAS_RESP_TYPE_NUM | HAS_STATE
State: OPEN, SUSPECT, NONE, "All connections pending"
Group: 0000
RespTypeNum: 0 (RespType.SOLICITED)
