Open PermID API request for https://permid.org/1-4294952829
If I go to https://permid.org/1-4294952829, there is a link imageView API response
If clicked, it produces a json output.
Could you please let me know how I could query the PermID API to get the same result?
Thank you very much for your help.
intelligent-tagging-apipermid-apiopen-permid-apitrbc
23k 22 9 14
23k 22 9 14
Hello @00000000,
Please go to to OpenPermId -> Entity Seatch ->Dev Tools->Swagger
And switch format from "turtle" (default) to "json-ld", this should get you a json formatted response.
Hello @zoya.farberov
Thank you for your reply. Right now, I can not get any information at all through the API go get the information. Could you please provide a sample curl command, which can be used to access through the API information provided on https://permid.org/1-4294952829 ?
