Dear Support,
I would like to ask for your help regarding the News pluggin. I am using App Studio web Sdk.
I managed to fetch the headlines, as per the example given in Top&Basket documentation of Jet pluggin. However, I would also like to get the stories behind the headlines (to be able to open the headlines and see the body of the story). If that is possible, how can I achieve it?
I did notice that to open a news you do :
JET.navigate ({name:"News", entities:[{NewsQuery: query }]})
but I was not able to use that in the News object (jet.News.create()).
I would also like to ask, what the "A" means from the following expression: .newsExpression("A"). Are there any other expressions that can be used apart from "A" or rics? I read something about N2_UBMS, but that's I think that is not working anymore.
When creating a subscription, I saw that this is used: JET.News.create("myID"); Could you please explain me how this works? From what I understood, when you do JET.News.create("myID") then you need to use an input field with your query(like in the given example). This is called subscription. The other option is to do .newsExpression("A") and this will run the headlines "automatically", without user input. Did I get it right ?
Sorry for so many questions, let me know please if you need more information.
many thanks in advance.
raluca
