In RFA configuration for RSSL consumer connections, we set the parameter "serverList" with the following ADSs:
"server74", "server75", "server76", "server09", "server10".
During an recovery training, the 3 first ADSs have been separated from the network so that they can not be reached by our RFA clients.
During our training RFA failed to connect to the 4th ADSs and we got the following error:
Error: RSSL Channel flush failed on connection "Default::Connection_Sub server76:14002". Channel will be closed. (Internal debug info: "<..\..\..\Rssl\Impl\rsslImpl.c:1692> rsslFlush() Error: 0007 Only Channels in RSSL_CH_STATE_ACTIVE state can flush.", errno: 0)
Can you give us more details about this error ?
We're using RFA C++ 7.6.2.L1.
Thanks.
