What is the rate limit for permid APIs?
I'm hitting an Error code 429 so wanted to get clarification on what my rate should stay under? Thanks!
apiintelligent-tagging-apipermid-apirest-apiopen-permid-api
@vna
It states in https://permid.org/faq that these services are limited to 5,000 records per API key (Token).
Are there any limitations on the free use of the TR Matching and Calais Tagging services?
These services are limited to 5,000 records per API key (Token). If you require larger volumes, please contact us at info@permid.org.
I have tried to send e-mail to info@permid.org but nobody replied. Could somebody please answer the following questions:
1) What are the terms and conditions of requesting more than 5000 records through the Open PermID API?
2) Is it possible to make requests through the Open PermID API for past dates?
Thank you.
