Getting error while appending identifer to instrument using Http Request
When I try to append identifiers through http request, Im getting below error:
{'error': {'message': 'Invalid request parameter Identifiers'}}
Im using below code:
OrderedDict([('Identifiers',OrderedDict([('Identifier','US8180971074'),('IdentifierType','Isin')])),('KeepDuplicates',True)]);
Can anyone help?
pythondss-rest-apidatascope-selectdsshttp
11.3k 25 8 13
The value of "Identifiers" needs to be JSON array. Please verify if your HTTP request.
Below is the sample of format. If the value is not JSON array, I get the same error.
    "Identifiers": [
            "Identifier": "US8180971074",
            "IdentifierType": "Isin"
    "KeepDuplicates": true
The code should be modified to be JSON arrays as follows.
OrderedDict([('Identifiers',[OrderedDict([('Identifier','US8180971074'),('IdentifierType','Isin')])]),('KeepDuplicates',True)]);
1.1k 4 3 5
One to many OrderedDict()'s I think.
Do you have the JSON that turns into: From the Sample App, this should work:
"Identifiers": [{
"Identifier": "IBM.N",
"IdentifierType": "Ric",
"UserDefinedIdentifier": "UserIdent4A"
"KeepDuplicates": false
