issues with installing of the EIKON API for R package
Dear EIKON R package Team,
I have faild to install the package THAPI (Laptop Asus x64 Windows 7).
I have downgraded R to 2.15.x (I tried all of 2.15x versions), run it as the administrator, then
install.packages('RCurl'); install.packages('XML'); install.packages('base64') (by the way, they did not work ok with 2.15.x; maybe the old realeses of them are also needed?), then I tried to instal THAPI.zip (install.packages("D:/Downloads/THAPI.ZIP", repos = NULL)) and ..no way.:
Installation d(es) package(s) dans ‘D:/Documents/R/win-library/2.15’ (car ‘lib’ n'est pas spécifié) Erreur dans read.dcf(file.path(pkgname, "DESCRIPTION"), c("Package", "Type")) : impossible d'ouvrir la connexion De plus : Message d'avis : In read.dcf(file.path(pkgname, "DESCRIPTION"), c("Package", "Type")) : impossible d'ouvrir le fichier compressé 'THAPI.ZIP/DESCRIPTION', cause probable : 'No such file or directory'.
what could you advise, please? Many thanks in advance.
Kind regards,
Roman
eikoneikon-data-apitick-history-rest-apirsetup
7.6k 15 6 9
@roman.matkovskyy
From the package name it's not Eikon API. Instead it should be TRTH API for request Tick Historical Data. Are you download the pacakge from https://developers.refinitiv.com/en/api-catalog/datascope-select/datascope-select-soap-api/downloads?
Based on below description from DESCRIPTION file in THAPI.zip, it requires R version 3.1.0 Built: R 3.1.0; ; 2014-05-13 05:26:57 UTC; unix
And
I have a chance to try it previously, and it seems not to work if you install R library using original .zip file. However I found workaround by unpack the package and repack all files from unpacked folder to THAPI.zip again.
Then I can load the new THAPI.zip in RStudio
Just try some function such as getQuota and it seems to work.
> library("THAPI")
Attaching package: ‘THAPI’
The following object is masked from ‘package:base’:
    serialize
> rdth<-createCredential("<TRTH Username>","<TRTH Password>")
> getQuota(rdth)
An object of class "Quota"
Slot "type":
An object of class "QuotaType"
Slot "value":
[1] "Unlimited"
Slot "usedCash":
[1] "0"
Slot "totalCash":
[1] "0"
Slot "usedOption":
[1] "0"
Slot "totalOption":
[1] "0"
Slot "usedFuture":
[1] "0"
Slot "totalFuture":
[1] "0"
Slot "exceedable":
[1] "true"
My R version is 3.3.1, but when I want to install this package, it shows Error in install.packages : type == "both" cannot be used with 'repos = NULL'
How do I solve it, thanks
@ moragodkrit
thanks a lot for your answer. Did as you advised.
Installed.
Thank you.
@moragodkrit
Thanks a lot for the detailed explanation, but I have still some issues.
I am using Microsoft R Open 3.3.0 and I installed the THAPI.zip package with no issues, but when calling library(THAPI) I get the following error
> library(THAPI)
Error in .mergeMethodsTable(generic, mtable, tt, attach) :
  trying to get slot "defined" from an object of a basic class ("list") with no slots
Error: package or namespace load failed for ‘THAPI’
Do you have any idea on what's going on? (BTW a Microsoft R Open 3.1.0 does not exist and I would pretty much use the Microsoft R open for windows optimization purposes)
Thanks in advance for your help.
7.6k 15 6 9
@mouhsine
The R library may works with 3.1.0 only and I don't see any update version for 3.3.0. Anyway if you want R 3.1.0, I found it on the following link
https://cran.r-project.org/bin/windows/base/old/3.1.0/
Thanks @moragodkrit.
Is there any way to get hold of the source code so we can package it for recent R versions?
