configure channel set using programmatically
How can we configure channel set programmatically in C++. It is not included in the given example in the config guide.
Is there specific example that I can refer related to this.
elektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-apic++configuration
11.3k 25 8 13
There is an usage example in the EMA C++ Configuration Guide document of the EMA 1.0.7 version's package. In this example, the consumer uses two different set of Channel configurations in the ChannelSet configuration.
