Maximum map entry key size
Publishing items using the data structure containerType="MAP" what is the maximum allowable size for a mapEntry key value?
elektronelektron-sdkrrteta-apielektron-transport-apimap-entry
From my test with UPA 8.0.0.L1, if the keyPrimitiveType is a buffer or string, the maximum length of the key buffer is 32767 bytes.
